New SES Codes!!!! Yippeeee!
Old Jun 27, 2005 | 04:05 PM
  #21
Black_Silverado_5.3's Avatar
Originally Posted by Texas Terminator
ewwwwww! the infamous #7. how much boost are you running? do you have bigger injectors? how hard do you drive it? pull the plug and take a good look at it. check for shiny particles.
...Shiny particles
Old Jun 27, 2005 | 10:38 PM
  #22
1SlowHoe's Avatar
Destroyer of Transmissions
Had a guy check the power on ground on the injector clip, it was fine. He did an ohm resistance test on the injector itself and it seemed to read ok as well. The misfire and corresponding rough idle are not constant it comes and goes as if the injector is firing sometimes and sometimes not. I am going to replace the injector and see what happens. I didn't want to swap injectors around to test #7 because if I'm gonna take it apart I'm gonna put a new injector in there. Tomorrow we are doing a compression check and an injector balance test, hopefully this will confirm the injector is bad and I'll replace it. I'm not driving the truck unless absolutely necessary.
Old Jun 30, 2005 | 01:34 AM
  #23
1SlowHoe's Avatar
Default Hmmm, too easy?
Swapped the injector, no more misfire, smooth idle. I guess I'll wait a few days for the next code and see what I have to fix next. For now it runs great other than the neck snapping 1-2 shift at 1/4 throttle, damn built 4L65E!!
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
legerwn
56
Nov 15, 2015 10:21 PM
bearden86
26
Nov 15, 2015 03:58 PM
