New SES Codes!!!! Yippeeee!
Old Jun 25, 2005 | 07:13 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Default New SES Codes!!!! Yippeeee!
The new codes are P0200 Injector circuit open and P0307 Cylinder 7, misfire detected.
I'm gonna go out on a limb and say the cylinder 7 has the open injector circuit. How do I locate #7? If I pop the hood and look at the engine is it left side/right side/third from the front etc....? I want to check for bad wiring before I go buy 8.1 marine injectors Would this be causing the surging I get once in awhile? The truck surges now at an idle if I don't have the foot firmly on the brake. Not all the time but often. My SES light actually blinked for over an hour today while I was stuck in traffic, what's that about?
Also, the newly installed tranny still has some light chattering from time to time. My tranny guy wrote this on the invoice for me to tell my tuner..."Computer (TCM) is responding too slowly. Appears EPC is not getting full voltage with heavy acceleration. Reverse has a 2.5 second delay!" I don't know what all that means. Help with all these issues is appreciated.
Old Jun 25, 2005 | 07:15 PM
1SlowHoe's Avatar
Default Forgot....
Oh Yea, And is it ok to drive around with an occasional misfire? Am I just gonna foul a plug or am I gonna do real damage?
Old Jun 25, 2005 | 07:27 PM
SnakeOiler's Avatar
#7 is the rear cylinder on the driver side
Old Jun 25, 2005 | 07:35 PM
1SlowHoe's Avatar
Outstanding, let me go take a look.
Old Jun 25, 2005 | 07:59 PM
Texas Terminator's Avatar
11 Second Club
ewwwwww! the infamous #7. how much boost are you running? do you have bigger injectors? how hard do you drive it? pull the plug and take a good look at it. check for shiny particles.
Old Jun 25, 2005 | 08:18 PM
therock's Avatar
Default There Are GM TSB's on....
....# 7 missfires.
Old Jun 25, 2005 | 09:11 PM
litreddevil's Avatar
Banned
And I Thought I Was The Only Person To Blow #7 Cyl. Not Once But Twice.
The Ses Is Blinking Cause The Motor Is Miss Firing @ That Time Not Good To Drive It While Ses Is Blinking.
Unplug The Injector Plug And Take A Test Light And Connect It To Both Sides Of The Connector For The Inj. And Start The Motor And See If The Inj.is Pulseing,if The Test Lights Up Then It Is Pulseing.
It Would Probably Be An Inj.
But While You Have The Plug Out Check Compression Cause #7 Cyl. Is The Last Cyl. To Get Fuel Pressure And Fuel.so If It Ran Lean For Any Reason
Say Good Bye To That Motor.
One Question Do You Still Have Cat(converters) Cause That Can Cause A Lean Condition And Cause The Motor To Blow Also.(i Have Seen This More Than Once)
Old Jun 25, 2005 | 09:17 PM
1SlowHoe's Avatar
Boost-- 3.4" pulley, about 6-7 #'s
Injectors--Stock for a flex fuel truck, unknown flow rate, maybe 30#'s?
How hard do I drive-- Is there any other way?
I have a guy who's going to look at it tomorrow. He is looking up bulletins right now. Anybody know the # bulletin that references this issue?
Old Jun 25, 2005 | 09:19 PM
1SlowHoe's Avatar
I still have the factory cats, I didn't know they were a problem.
Old Jun 25, 2005 | 09:20 PM
budhayes3's Avatar
PT's Slowest Truck
I wouldn't drive around with a misfire myself, but at least if it's an injector issue (injector not pulsing), you're not dumping raw fuel so you're not flooding the #7 cylinder and l/s cat. Seems like injector failures on #7 is fairly common...like the rock mentioned, there's even a TSB about it.
