Whipp'd 5.3; cam/head opinions please
I'm running a 7# Whipple boost on a stock 5.3 ('04). It's time for more power. I'd like to put out min. 400rwhp. Due to the blower I'm thinking about either a stock LS6 cam and Heads because I can afford to lose compression OR GMPP #88958665 Heads w/65cc and maintain 10.5:1 w/88958606 Cam 239/251 570/570 106.5.
It's my DD, too.
Thx!
It's my DD, too.
Thx!
The "forum search" was working today and I found alot of info about the LS6 Heads/Cam here. Seems to be pretty played-out already.
But, I'm not having much luck finding info about a good set up for the s/c'd 5.3.
It looks like doing the top end, I'll be way overshooting my target of 400rwhp
So, what would optimize the blower?
I run a 62cc chamber and Comp 212/218 .558/.563 115lsa+2
I'm running about 9.0:1 compression. You could easily do 9.5:1 compression on 12psi and get better results. I maxed out my timing on 6psi at 23* Any higher shows no gains. hence you can go with higher compression and be okay.
Easy 400rwhp on 6psi.
echoman
Aug 22, 2015 01:53 PM
