new motor going into the truck
Old May 27, 2017 | 11:03 PM
03rcsbT56's Avatar
Registered User
Default new motor going into the truck
went to swap a tsp cam into my 4.8 and the cam bearings was shot so i decided tp just go ahead and do a motor swap. i looked all around for a lq9/4 and couldnt find anything so i found a forged ls1 long block that i purchased.
5.7 ls1
forged pistons/rods
stock crank
11:1 compression
239/242 cam
afr 230 heads
going through a t56 ls7 clutch with yukon locker with 4.10 gears
anyone guys what numbers i would put down on a dyno and 1/4 et?
Old May 28, 2017 | 10:54 AM
darkirish63's Avatar
5.7 ls1
forged pistons/rods
stock crank
11:1 compression
239/242 cam
afr 230 heads
Amen lot of folks more knowledge than I am here but more info would be needed like - 4WD or 2WD / weight, etc...
Old May 28, 2017 | 06:07 PM
03rcsbT56's Avatar
Registered User
2wd and not sure on weight 4300# maybe?
Old May 29, 2017 | 02:14 PM
07NBSChevy's Avatar
Over on LS1Tech, a guy has a 2002 Camaro LS1/M6 with the MS4 Cam (239/242 .649/.600 111.5 LSA), Stage 1 Ported 243 heads, 1-7/8" longtube headers, LS6 intake, 4.10 gears and made 420 Hp/370 Tq at the wheels.
I would guess you should run mid 11's.
Old May 30, 2017 | 01:55 AM
03rcsbT56's Avatar
Registered User
guy with exactly same build but in a Fbody said he put down 470 whp
