new guy with questions
Old Apr 13, 2010 | 11:42 PM
Evilution's Avatar
Question new guy with questions
I am having an 02 gmc rcsb 5.3 tranfered in. I had a few questions for you guys in the know.
1. what size cam should i throw at it? (im thinking 224/224)
2. who would you suggest i get heads from (i know its a personal preference thing but what was your choice)?
3. do the flt built 4l60e's hold up or should i go with a 4l80?
4. who makes the best long tube?
5. how do you know what rear ratio your truck has from the factory?
basically looking to build a solid heads/cam/nitrous 5.3 truck and when that goes build a 408. is the 224/224 cam good for the 5.3 or should i go bigger/smaller?
Thank you all,
Marty
Old Apr 14, 2010 | 12:41 AM
Evilution's Avatar
also do i need a 1 or 3 bolt cam?
Old Apr 14, 2010 | 12:48 AM
03chevyroyce's Avatar
welcome!
1)depends on application (street/strip.etc)
2)once again, depends on application. if you get heads, get a cam to match them
3)i have heard a TON of good things about FLT. PM vince, he'll tell you more
4)there are a few manufacturers that make good long tubes. Pacesetters is the best bang for your buck in my opinion
5)there's a sticker with a lot of codes in the glove box. im not sure which one it is, maybe someone can give you a little more insight on this
6)3 bolt cam. your 02 is a generation 3 motor, so it has 3 cam bolts
hope this helps ya
Old Apr 14, 2010 | 01:15 AM
Evilution's Avatar
Thumbs up
Originally Posted by 03chevyroyce
welcome!
hope this helps ya
thank you sir i figured it was a 3 bolt but wanted to check. another question which shop would you recommend in the houston area? fastlane/mti/LME or who?
Thanks again
Old Apr 14, 2010 | 01:23 AM
depends on what you are looking to get done
Old Apr 14, 2010 | 02:49 AM
Evilution's Avatar
just looking at a cam swap and maybe heads. not sure on the heads yet. also who offers lockers for these cars? i have hear there is a true trac. is there a real detriot locker that fits? what rear gears do these 5.3 trucks come with? i know the towing package has 3.73's but what about the non towing? also are these truck 28 or 31 spline from the factory?
Thanks
Old Apr 14, 2010 | 10:32 AM
Evilution's Avatar
also whats the biggest cam you can go on a 5.3 and still pass emmissions?
Old Apr 14, 2010 | 10:37 AM
charcoal03silvy's Avatar
About your gears, its a G code. GUx i believe, the x will be a number. Google it and it will tell you what you have.
You probably have 3.42s
Old Apr 14, 2010 | 10:40 AM
Evilution's Avatar
thank you sir i will do that
Old Apr 14, 2010 | 09:57 PM
Evilution's Avatar
as far as headers go how much of a difference (rwhp) do long tubes make on a bolt on 5.3, on average ofcoarse...?
