New Exhaust and some info
I've been planning to open up my whole exhaust as I knew it was a restriction at the Air I was moving. Some of you may have seen that I went to a larger cam a couple months ago, upon doing so my single 3" exhaust started sounding like a big air leak at WO. I already upgraded my old headers earlier in the summer, I switched to Kooks 1 7/8 3" collectors. This got me curious so I put a back pressure gauge on it, at WO my pressure was 10psi in first gear and kept climbing when I hit second so I just said screw it and let out. Time to get this exhaust done.
I did dual 3" into a dual 3" in / single 4" out merge. I used a Flo Pro Dmax mid pipe into a Magnaflow SI/SO then a Magnaflow universal 4"tailpipe. All stainless and V band clamps used for easy of removal etc.
Some things to note, the big Magnaflow muffler is a 3.5" core, I couldn't find a good large case 4" muffler that wasn't a diesel style muffler. I knew 4" was gonna be hard to keep tolerable sound wise so figured I would try the 3.5". Many forget the fact that a 3.5" core muffler is really 3.5" where as a 4" pipe is more like 3.75-3.8 as its measured in OD not ID like a muffler. So I figured I would try it and check back pressure and go from there. Much to my suprise there wasn't any. I lost about 1.5 psi boost and was a bit lean on topend.
It was also loud, so that started the next project. Adding in a resonator. Pics to follow.
Magnaflow 4" tail, had to modify it as my Dana 60 rear and QSteer requires more clearance then a standard axle.
Tail modified
Tail modified
The resonator is now 10" long, we took 2" off each end, kept the Magnaflow logo centered. Best of all it removed the drone and it sounds great! I need to get a WO video. I dropped down to a 2.9" pulley now to get boost back to 15ish
I couldn't have done it without the help of my buddy Mark ( Mark Buck)
Did you have to make the dual 3 inch merge to single 4 out? I plan on running 4 inch on my cammed lq4 when I get it in,I really like how you did this and it looks very well put together, I will be running something a little more on the loud side tho, thinking a small borla xr1
