new ET!!!
single digit dreamer
i am prety fired up right now.let me lay down the senaro before i give the time.
stock shift points, 5200rpm, not sure if this is hurting me or not.
bone stock 5.3 tuning
14deg of timing but 8 full deg of KR the whole run so only 6deg of timing total
55deg
1/2 tank of gas
full weight LT, trailer hitch, spare tire all still there.
in auto 4wd with signifacant wheel slip
6psi, actualy heard a little pinging right at the end of the second run
13.59 and then turned right around and ran a 13.68 in the oposite direction. i am prety happy with those times for now but it still feels slow. looks like i need to get a wide band and adjust my fuel then see if i can get a little more timing.
seems to me a little tuning and drop 200lbs(gate, spare, jack, back seat,) i might be knocking on the door to 12's
55deg
1/2 tank of gas
Adkoonerstrator
That's awesome!!
That timing/KR problem is killing you though. There is ALOT of potential in those lost 8 degrees. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Did you ever run any 100+ octane to see if your knock went away? I just don't understand why 6psi in 55 degree weather is causing that much knock, especially with only 14 degrees of timing. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I'd be very careful about it. I wonder if its load/heat induced.(kinda like driving uphill in the middle of summer at half throttle) Your truck does weigh close to ~5500? lbs. which is alot of weight to be hauln. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Anyway congrats on the 13 sec. run, 12's aren't too far away. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
John
John
the knock is real, i could hear it on the 2nd run. i have my knock sensor desensatized 30% and it still goes strait to the max 8deg and stays there. i don't plan on making any more runs until i get that under control. i believe i have some false knock and some real knock. i think i have the false knock under control and now any knock i see on atap is probably real.
i agree 6psi and 55deg temps should not be knocking, i am runing 92 gas. i have 2 theorys, air fuel ratio is way off causing it to knock. or there is some kind of problem in the combustion chamber. i got the engine with 4,000 mile on it but it had been hydro locked, it had a bent rod that was replaced before i got it. the guy i got it from may have done something wrong like used a 5.7 head gasket.
gtech of course, i have alot of confidence in that unit, at the track it was never more that .05 off. they stoped running their friday night thing where anyone can run and i am prety sure they are done for the season for all kinds of racing but i am not sure.
i keep changing my mind about water injection, one day i am thinking yea, why not try and get another couple of lb's of boost then the next day i am thinking more tuning and i should just hit it with a 50shot. i shouldn't be having a problem at 55deg so i need to figure that out first.
