New E-Fans, Where to put the Radix Tank
Old Jan 8, 2005 | 06:14 PM
KySilverado's Avatar
Default New E-Fans, Where to put the Radix Tank
Guys,
Modding again. Was going to do cam, e-fans, smaller SC pulley but decided to just do the e-fans and pulley due to time. Afraid I wouldn't get it done all in one day.
Anyway I have installed the new 2005 Electric fans and the shroud coupled with the extra width of a 34 inch radiator won't allow room for the pump and coolant tank on shroud like before. I have to move it somewhere and damned if can find a good spot. I've been looking around for couple hours now under that hood. Anybody got any suggestions on alternate locations. I'm thinking about screwing it to the passenger side firewall under the brace. Gonna be some long darn hoses running around and the pump up near the radiator.? How close does the pump HAVE to be to the tank? Can't believe I am letting this whooop me
Old Jan 8, 2005 | 06:18 PM
moregrip's Avatar
what a rush!
Originally Posted by KySilverado
Guys,
Guys Modding again. Was going to do cam, e-fans, pulley but decided to just do the e-fans and pulley due to time. Afraid I wouldn't get it done all in one day.
Anyway I have installed the new 2005 Electric fans and the shroud coupled with the extra width of a 34 inch radiator won't allow room for the pump and coolant tank on shroud. I have to move it somewhere and damned if can find a good spot. I've been looking around for couple hours now under that hood. Anybody got any suggestions on alternate locations. I'm thinking about screwing it to the passenger side firewall under the brace. Gonna be some long darn hoses running around and the pump up near the radiator.? How close does the pump HAVE to be to the tank? Can't believe I am letting this whooop me
Very Easy, Call Magnacharger and order their new IC Tank Mounting Plate, mounts to your under-hood fuse panel, VERY CLEAN!!!!
Old Jan 8, 2005 | 08:27 PM
GMC_DUDE's Avatar
I squeezed mine between the battery and the radiator, and bolted it to the radiator cross-member.
Old Jan 8, 2005 | 08:35 PM
BlownChevy's Avatar
blownerator
25 Year Member
Only problem there is the heat from the radiator keeps the water in the resvoir warm!
Call me on Monday guys I will order you a new bracket.
Old Jan 8, 2005 | 09:24 PM
I mounted mine with a piece of aluminum behind my electric fans.I did stabilize the tank with a zip tie below as it sometimes touched to fans when I stopped hard.
Old Jan 8, 2005 | 10:28 PM
Sent you a PM
Thanks! I'm a bit concerned about the longevity of my quick engineering. Tie wrapped the dang thing to the fuse box! Had to try out the mods!
Pulls harder at 8psi
Old Jan 8, 2005 | 10:29 PM
BlownChevy's Avatar
blownerator
25 Year Member
Sent you a PM
Got the PM, give me a call monday! 805-642-8833
Old Jan 9, 2005 | 02:24 PM
Green Thunder's Avatar
Do you have any pics of the coolant tank and bracket?
Old Jan 9, 2005 | 10:36 PM
Flyer's Avatar
What about here:
http://www.woracing.com/truck/RADIX/100_0673.JPG
http://www.woracing.com/truck/Batter...n/100_0671.JPG
Old Jan 9, 2005 | 11:35 PM
Thanks
