New Dyno Numbers 549rwhp and 564rwtq
Old Jul 1, 2004 | 03:06 PM
GMC SKI's Avatar
Default New Dyno Numbers 549rwhp and 564rwtq
Went to the Dyno agian yesterday to try out the new tune I got done to remove the torque mangement i couldn't get rid of
Best pull was on 15.8Psi with the exahust uncapped made 549.91rwhp and
564.15rwtq Unlocked covertor
When he hit it on the dyno it shot up too 15psi almost instant and stayed there untill the run was over
I had a few issues i had the boost controller set at 18psi and i couldn't get it to break 16psi ..so i think the wastegate spring needs changing
With the exhaust on we saw instant 10psi and then climb to 14-15psi
The tires were slippping on the dyno some so next time I have to dyno with my slicks
All the testing was done on Pump Gas
No KR on any of the runs at all running about 18-20degrees of timing
Got the wastegate out of the truck now and going to figure out what spring to put in it
Pretty happy with the results so far just need more boost I wanna end up with near 20psi if i can with some c-116 race gas
Track times are coming soon
Old Jul 1, 2004 | 03:10 PM
Deckhand's Avatar
Badass man..
Setting new standards for modern truck performance, good job.
Old Jul 1, 2004 | 03:23 PM
XLR8NSS's Avatar
Adkoonerstrator
Absolutely awesome Jim. On pump gas too.
Old Jul 1, 2004 | 03:57 PM
2ksleeper's Avatar
Nice numbers GMCSKI .
Is there any advantange or disadvantage of running the truck with a locked vs. unlocked convertor on the dyno or at the track?
Old Jul 1, 2004 | 04:05 PM
BigBlockChev572's Avatar
Geeze! Your my hero! Very impressed with your results. Figuring a 20% loss of power through drivetrain you have 658.8 at the flywheel!
Make a video of your track runs!
Philip S.
Old Jul 1, 2004 | 04:14 PM
CurtD's Avatar
10 Second Truck Club
Amazing numbers thats crazy power
Old Jul 1, 2004 | 04:47 PM
GMC SKI's Avatar
I have some Dyno footage
Borrowed my buddies Video Camera but he forgot to give me his Cable to make them into some Mpegs
I'll try and get the vid up in a few days
Just got finished installing the new wastegate spring and shims
Man what a Pain in the *** to get the freaking thing out. One of the bolts is barried almost against the downpipe can't get anything on it so i ended up using a pair of needle nose to tighten it ...getto fab action but it's in at least
time for a test drive
Old Jul 1, 2004 | 05:11 PM
parish8's Avatar
single digit dreamer
locking the converter will give you higher numbers on the dyno and usualy make it easier to get lower rpm numbers. it also makes comparing numbers a little easier, takes the converter out of the mix.
locking the converter at the track mid run will typicaly give you 1-2mph but no ET, i dont really under stand how that can be but that is what everyone says.
Old Jul 1, 2004 | 05:12 PM
parish8's Avatar
oh yeah, nice numbers! who has the highest dyno numbers for the trucks? seems like that might be it.
Old Jul 1, 2004 | 05:49 PM
GMC SKI's Avatar
We ran out of time on the dyno and i didn't get a last run in with the convertor locked up ..too Bad Could have been interesting
Looks like I might have a chances at top spot now that your broken.
but who knows Need some more power to account for the 75shot your running
Some Ice in the tank and 5 more psi should do it little Splash of c-16
