New dyno numbers
Old Aug 26, 2005 | 08:45 PM
ranwalk's Avatar
Default New dyno numbers
Today was not the best day for this(hot as hell), but I wanted to get the truck tuned with the new setup so I knew I wasnt hurting anything. Took a trip down to Futral Motorsports and let Allan do his magic.
Run conditions were 101.41 degrees Did I mention it was hot out
Numbers made were......
461.34 rwhp
455.48 rwtq
Considering the heat I am very pleased with this. I wish i knew what it would have done if it had been a nice 50-60 degree day.
Old Aug 26, 2005 | 08:50 PM
boomers03gmc's Avatar
nice dude!!! who did u make bitch to be the fan man!!! lol
goshawk23's Avatar
Truck addict
hey that aint bad at all. what were the old numbers? i think hp wise i am falling a little short of you with spray. but you have a lighter truck so bye bye you go.
Old Aug 26, 2005 | 09:15 PM
v8
17,16,15,14,13,12,11 Drvr
nice #'s there, how much NOS you plan on spraying?
Old Aug 26, 2005 | 09:18 PM
moregrip's Avatar
what a rush!
461.34 rwhp
455.48 rwtq
Congrats Bro! What are your mods again?
hmmm, getting closer to 500/500
Old Aug 26, 2005 | 09:39 PM
ranwalk's Avatar
Yep, I was so hoping to hit 500, but I knew going down there that as hot as it is I most likely could just forget about that.
Mods are...
Lq4 6.0(Built by Futral Motorsports)
Fully studded with ARP head studs,main studs,rod bolts
Diamond pistons dished(compression is 9:1)
Stock rods
Stock crank
Rollmaster double roller timing chain
Comp lifters
Hardened pushrods
FMS ported oil pump
Whipple-hot *** air blowing non intercooled pos(10psi boost)
FMS cam, 216/218
Comp 918 springs and titanium retainers
Minor head work(bigger valves)
K&N FIPK
Lt1 Electric fans
42 pound/hr injectors
4.10 gears
Yank TT3000 converter
Stock transmission
Pacesetter Long tubes
No cats
Single 3.5inch exhaust through Magnaflow dumped
I think thats all
Old Aug 26, 2005 | 09:40 PM
ranwalk's Avatar
No nitrous here, just a hot air Whipple. But some spray on top of it would be pretty interesting
Old Aug 26, 2005 | 11:10 PM
Searching4Sierra's Avatar
maybe you could look into a methanol injection set-up, they do wonders
Old Aug 27, 2005 | 04:12 AM
12sec.5.3's Avatar
Congrats on the numbers man. Should be some easy 11's, or maybe 10's. Will you be at the shootout?
Old Aug 27, 2005 | 05:29 AM
Wilde Racing's Avatar
How do I change this text
WOW, great numbers. I think you should check out a meth kit too with that kind of heat.
