New crappy track times&Denso plugs
after the stereo, tools and a nd much added weight, i weighed in at5400lbs w/o driver im 195 so 5595. I ran 275/45r20 goodyears I made 2 passes, the track was packed. air temp75 humidity72%. my times got worse.
60ftwas 2.166/2.177
1/8was9.17/9.12 mph76.12/77.34
1/4m 14.367/14.312
mph93.36/94.66
Tqm was worse than ever. it fell on is face arou 5900rm wot
The denso plugs made a differenc, it accelarates smoother, and idles better
the track sucked, humidity was bad, i even redlighted @4.999 Whats the problem?why is it running so shitty?
60ftwas 2.166/2.177
1/4m 14.367/14.312
mph93.36/94.66
5600 Lbs your trucks a PIG
Damn you gotta loose some weight to get some better times
can you even get a smaller pulley for the magnacharger?
get a smaller pulley and then get some tunning done on the truck to get rid of the TQM
tuning on the truck might be worth some tenths for sure
Try taking off those 20's. Those times are what mine did a while ago in 80degree heat.
<small>[ September 19, 2002, 12:54 AM: Message edited by: 1999stepside ]</small>
