new cam truck wont idle
Old Apr 10, 2010 | 02:10 PM
50adrod's Avatar
Default new cam truck wont idle
we just put a LS1 hot cam in a 99 siverado 5.3. it runs fine but wont idle. if you keep your foot on the pedal it is fine but as soon as you let off it dies. any ideas? no aparent vacum leaks
Old Apr 10, 2010 | 02:15 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds like some tuning is in order...
Old Apr 10, 2010 | 02:17 PM
50adrod's Avatar
I thought it would run on the factory tune, I guess not
Old Apr 10, 2010 | 02:24 PM
03chevyroyce's Avatar
no, you will need a retune. mine did the same thing with my new cam
Old Apr 10, 2010 | 04:44 PM
01SilvyZ71's Avatar
dont feel bad i made this same thread about a month ago lol
Old Apr 10, 2010 | 04:52 PM
Evil Eric's Avatar
hows the driveability with a stock tune and that hotcam? I had a friend that drove a stock tune trans am around after a magic stick install and it would buck like a wild horse when he would roll through a parking lot in first gear.
Old Apr 10, 2010 | 06:02 PM
GMCtrk's Avatar
The reason it's dying is because there's way too much fuel at idle for that cam. To idle properly you need to pull back anywhere from 20-40% of the stock fueling.
Old Apr 10, 2010 | 06:55 PM
dirt track racer 81's Avatar
the desired airflow in gear and desired airflow in park/neutral needs to be raised as well
Old Apr 10, 2010 | 07:21 PM
GMCtrk's Avatar
Yep, definitely true as well.
Old Apr 10, 2010 | 07:27 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
That cam will also want a little more timing at idle.
