New best in the 1/4!
Old May 30, 2004 | 12:32 PM
  #21
Originally Posted by Snake Eater
Sweet thanks. I'll go the cheaper route. What psi does yours idle at?
Does the gauge screw onto the rail?
Each year is different on what psi it is set at. They do it by color code like in the quote I put from oxidizr. You have to check it with the vacum line off on the regulator. Mine was set at 57 lbs with the line off...so I bumped it up to 62 lbs when I sprayed. The best way to do it is to put the guage on and check it before you try to adjust it. You have to get an npt 1/8 swivel fitting for the guage to fit on the schrader valve.
Old May 30, 2004 | 12:51 PM
  #22
Sorry to ask, but could you get some pics of it too?
Old May 31, 2004 | 02:10 PM
  #23
OK here are the pics of the kit, nitrous line in the filter, regulator, and fuel psi guage.
Old May 31, 2004 | 02:28 PM
  #24
BADMOFO's Avatar
Cuz I AM a BADMOFO
Thanks for the pics! I was wondering if it could be used with a conical filter since I have removed my stock air box. I suppose it has something to hold it into the air cleaner element??
Old May 31, 2004 | 02:47 PM
  #25
yes we used a compression fitting that came with the kit to hold it in the air filter
Old May 31, 2004 | 02:56 PM
  #26
Thanks for the pics! You got a better bag than me, and they gave you a pressure gauge. I guess there getting more popular and getting better materials. I never did use the bag though. I just took the bottle off the plywood and mounted it. Sweet with the fuel thing though.
Old May 31, 2004 | 03:06 PM
  #27
Sport Side's Avatar
is that push button activated or what?
Old May 31, 2004 | 03:09 PM
  #28
yep, its on a slinky cord that plugs into the cig-lighter. Its a really simple kit.
1-bottle
1-soleniod
1-line
1-jet
1-cord with push button
Old May 31, 2004 | 03:48 PM
  #29
I ordered the pressure gauge with the kit...It was like $45 more.
walledition
Feb 24, 2026 03:27 PM
TAPyvehc93
Jan 8, 2016 10:47 AM
Chavette
Oct 28, 2015 07:33 PM
DrX
Sep 29, 2015 04:31 AM
askkmb
Sep 7, 2015 10:58 PM
