New 402 is on it's way
Old Dec 6, 2005 | 07:09 PM
CHarris's Avatar
Default New 402 is on it's way
I called up Scoggin Dickey yesterday and ordered up a new Iron 402 to get things off to a good start on my new H2 build up. Boy am I happy I called them!
Here's what I got...
Iron 6.0 block w/ std bore
Eagle 4.000 stroke crank
Crower 6.125 I beam rods w/ARP rod bolts
Diamond -14cc dish pistons
Diamond plasma moly file fit rings (set up for up to 150 shot or 8lbs of boost)
Clevite rod and main bearings
Durabond cam bearings
New truck oil pan
New LS6 oil pump
New windage tray
New oil pickup tube
Crated and shipped to my local freight station for less than $4200
I was especially impressed with the time that Kris took to explain everything and to help me identify the other parts I needed to replace my fragged pieces. That's customer service that can't be beat!
This is going to be a very good foundation for an impressive build up.
Thanks, Kris (at Scoggin Dickey)!
Old Dec 6, 2005 | 07:33 PM
TwoFast4Lv's Avatar
10 Second Club
Heck yeah! Gotta love good service
Old Dec 6, 2005 | 07:41 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
ONly good for 8#s of boost dont you think you will go higher than that?
Old Dec 6, 2005 | 07:42 PM
1slow01Z71's Avatar
or boost and nitrous combo again
Old Dec 6, 2005 | 08:31 PM
I was very close to buying that same short block. Can't wait till spring so the 8lug battle can continue.
Old Dec 6, 2005 | 08:36 PM
BigTex's Avatar
Wow, thats a great buy. Please hurry up and get it all built and installed. I'm really interested to see how much boost the Radix can feed a 402.
You know, that combo is going to make some HUGE torque!
Old Dec 6, 2005 | 08:55 PM
Sounds like the Hummer is on the road to recovery,What pulley are you planning to use?With a 2.75" pulley my 403 makes 7lbs of boost.What heads and cam are you planning to run?
Old Dec 6, 2005 | 09:14 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Sweet deal. I as well almost bought that short block. I asked about it taking 8lbs and a 100 shot and was told it would need the rings reworked or something, and be a little more $. Then I found my 6L.
The Hummer is gonna love that TQ!!
Old Dec 6, 2005 | 09:18 PM
gonzo 6.2's Avatar
HEY! What about heads? Didnt he try and sell you a longblock with modded heads?When will your 402 be shipped?
Old Dec 6, 2005 | 09:22 PM
BigTex's Avatar
If I could get 7psi from my Radix on a 402, I'd be very tempted to do it. As it is, I'm only getting 8.5psi on my 6L with the 2.75" pulley. My N/A camshaft is part of that issue though.
