Nelson Performance
Old Feb 12, 2005 | 09:22 PM
Default Nelson Performance
I'm not the most computer savy person in the world. Is there a way to order an ls1 fan harness from Nelson online, or do I have to call?
Old Feb 12, 2005 | 09:35 PM
I dont think he has secure online ordering, just give him a call.. Nicest guy you'll ever talk to.
Old Feb 12, 2005 | 09:42 PM
Thanks...I'll call him on monday.
Old Feb 12, 2005 | 10:31 PM
Flyer's Avatar
Call or EMail .. I think he's gotten pretty snappy with email. IMO though, I would NEVER ever send any CC info through email though. It's all in clear text with no security. PayPal would be OK though. I dunno if he still uses PayPal or not though.
Old Feb 12, 2005 | 11:38 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Hey Badzracing, just give me a call or email me at allen@nelsonperformance.com , we accept paypal.
Here's a bit of info on the harness:
The fan harness we supply comes with everything you need to get your fans working correctly. I supply the OEM connectors for the ls1 fans and additional hardware for the flex a lite fans. The harness is completely wrapped in loom, all joints are soldered and I use fusible link instead of fuses, just like your starter wire.
To install, you simply supply ground and power, tap into the a/c green wire and push the supplied wire and terminal into the pcm. All ground, power and a/c points are at the red junction box on the side of the driver’s side engine. So there’s no hunting for wires. The pcm wire simply pushes into the blue connector at pin 42.
The harness has three speeds. Here’s how it works.
The pcm is programmed to ground pin 42 when it reaches a turn on value and off when it reaches a turn off value. When it does ground the pin, it will activate both fans and turn them on low speed.
When the a/c is turned on, the green wire has 12volts applied; both fans will turn on high, as long as the pcm has reached its turn on value.
If the engine hasn’t reached its turn on value and the a/c is turned on, one fan will turn on high. This will keep the a/c cool.
The harness is $89 and I can ship immediately.
thanks,
allen
Old Feb 13, 2005 | 02:40 AM
VicRed's Avatar
I have been very happy with my fan harness
Old Feb 13, 2005 | 04:11 AM
bluecajun5.3's Avatar
11 Second Truck Club
by installing the nelson harness, does it require any pcm tuning?
Old Feb 13, 2005 | 07:30 AM
one03sierra's Avatar
Formerly one92rs
Talking
yes the fan on and off will have to be turned on in the pcm. more than likely you will have to get it tuned for this.
Old Feb 13, 2005 | 09:18 AM
Allen, I sent you an email. I can/will buy it today so it can be shipped monday. Thanks everyone.
Old Feb 13, 2005 | 12:09 PM
nightmarechevy's Avatar
You won't be upset with the Nelson harness, well worth the money. I LOVE mine!
mikeyjm1
17
Oct 29, 2015 11:04 PM
gaps
Oct 15, 2015 02:53 PM
gavin2005
Sep 13, 2015 09:04 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
montecarloss
Sep 2, 2015 04:44 PM
