nelson fan harnest ?????
Old Oct 17, 2009 | 03:58 PM
MISTERIO's Avatar
Default nelson fan harnest ?????
well i just got my fan harnest intalled on my 2001silverado an the may fan does not want to turn on!!!! does any body know if i have to get them tune so i can work????
Old Oct 17, 2009 | 04:16 PM
tarinitup's Avatar
9 Second Truck Club
Yes, you have to tune the truck for electric fans to come on. One fan works on high speed with the A/C if you plugged it in to the right green wire to trigger it.
Old Oct 17, 2009 | 04:27 PM
MISTERIO's Avatar
yes that other fan turns on at the same time as the fan cluch does
Old Oct 18, 2009 | 03:01 PM
LS1TRUCKGUY's Avatar
gotta getta tune
Old Oct 18, 2009 | 03:31 PM
neilownz's Avatar
There's a way around it I think. Lemme find the info.
on the nelsons 3 relay harness if your computer wont turn on fans,you can wire a switch to the blue wire that goes to terminal 42 0n pcm to ground.this will turn on both fans on low.and green wire that goes to ac wire can also be wired to a swicth to battery voltage and this will turn on one fan high.and if you have both switchs on,both fans go on high for good cooling.
Old Oct 18, 2009 | 09:12 PM
budhayes3's Avatar
PT's Slowest Truck
That is correct, without the PCM tuned, you will either need a manual switch or one of those crappy probes that go into the radiator....
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
kalikid06
Sep 20, 2015 07:46 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
