Need some tech advice on Evaporative Emissions Control system
Old Feb 13, 2005 | 02:59 PM
linhardt's Avatar
Default Need some tech advice on Evaporative Emissions Control system
My 03 Silverado 5.3L is throwing a P0449 Code. Which is the Evaporative Emissions Control system vent valve/solenoid circuit malfunction.
Would that code come up because I installed a K&N FIPK and it is causing problems with the system??
I don't want to take it to the dealer and have them look at it and say the K&N is causing the problem and we will not service it under the warranty.
Is there something simple I can do to check the problem or possibly fix the problem??
Need some good advice on what I should do at this point.
Thanks!
Old Feb 13, 2005 | 03:10 PM
ta12sec's Avatar
put the stock air box on and take it in. I dont see how a air cleaner will throw evap faults but what do I know
Old Feb 13, 2005 | 03:18 PM
that has to do with the fuel evap system. First step is check to make sure your fuel cap is tight, then I'd take it to the dealer. The K&N won't affect it, and they shouldn't say anything.
Old Feb 13, 2005 | 03:24 PM
BlownChevy's Avatar
blownerator
25 Year Member
Correct.
Have you done any other mods??
Old Feb 13, 2005 | 03:36 PM
linhardt's Avatar
I have been searching the internet about it and I came across the same conclusion that it does not effect the EEC system.
I checked the gas cap and it was tight. I have been a little over a week since I filled up and I have about 1/4 tank left. So a loose gas cap may not be the problem. Might be the valve/solenoid circuit itself.
No, I have not done any other mods.
I do have a PCM coming from PCMforless which should arrive in the next day or two.
Should I have the dealer look at it before I install the PCM from PCMforless??
Old Feb 13, 2005 | 04:33 PM
BlownChevy's Avatar
blownerator
25 Year Member
I would. If the for some reason re-flash your PCM you are screwed.
Old Feb 13, 2005 | 07:44 PM
linhardt's Avatar
Thanks you all.... I will get it checked out tomorrow.
Corvette454l88
Sep 1, 2016 01:24 AM
thunder550
Oct 8, 2015 04:53 PM
FlowmasterMufflers
Aug 17, 2015 04:44 PM
