need some Push Rods
Old May 29, 2004 | 11:05 AM
Flyer's Avatar
How high are you wanting to turn the motor, or better yet, how high are you willing to let it spin?
Old May 29, 2004 | 11:06 AM
ktmrider's Avatar
Texas Speed and Performance ( on the right ) has some good prices on theirs. They even have different lengths if you have shaved heads.
Old May 29, 2004 | 11:11 AM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I like the higher l/s in the trucks, more like 114 or 115, but that is because I don't want any idle issues. Read the cam install instructions at www.ls1howto.com and check out the part about picking out a cam. With the added weight of the trucks and the fact that they are all automatic's I think the 114 l/s will work better in our trucks. I just ordered the 212/218 558/563 Comp for my new 6.0L, as that seemed to be the most popular and most recommended around here by the people in the know. You can also use this calculator to figure out what your lift will be with those 1.85 rocker arms you have. Here is the link: http://www.thedirtforum.com/rockercalc.htm
Old May 29, 2004 | 03:49 PM
Why not be the first truck to run a T-Rex? That would get you mid 13s easy, and sound like top fuel doing it. Not to mention the awsome 9mpg improvement.
The 113 LSA would be great for a daily driver. 112 would lope more, and MAY give you a little trouble in cold weather and around town. With a good tune though even a 112 could be an easy daily driver.
Old May 30, 2004 | 12:52 AM
ThunderZ28's Avatar
12 Second Club
well I am looking for a GOOD loping cam.
probably somewhere in the 6500 to 6800 rpm range.
Old May 30, 2004 | 01:28 AM
Flyer's Avatar
You have a 3000'ish stall converter right .. ?
If so, I would go with a 216/220 or 218/224 on a 112 or so. Prolly the smaller one since it's on a 4.8. If you can stand to do away with your rockers maybe get it ground with XEr lobes.
Old May 30, 2004 | 01:31 AM
F8L Z71's Avatar
I'd install the cam and stock pushrods. Then tighten everything up and check your preload. Then decide what pushrods to get
Old May 30, 2004 | 01:47 AM
Flyer's Avatar
Not a bad idea ... run it easy on the stockers til you get the better ones.
Old May 31, 2004 | 12:11 AM
ThunderZ28's Avatar
12 Second Club
ok what could I expect with this cam?
212/218 522/529 114 LSA
Old May 31, 2004 | 12:13 AM
one03sierra's Avatar
Formerly one92rs
Talking
216-220-525-532-114 might be better. you might want to get a bigger one.
