need some Push Rods
Old May 28, 2004 | 10:27 PM
ThunderZ28's Avatar
12 Second Club
Smile need some Push Rods
anyone have some suggestions, on a good set of push rods.
I am running 8.5 rocker arms. and i am going with 918 springs at the moment, but I might upgrade to a bigger spring depending on the serverity(sp) of the lift on the cam, that will come in the future.
anypart numbers, and price would be appreciated.
Thanks,
Daniel
Old May 28, 2004 | 10:38 PM
FILE's Avatar
You need some 7.4". Eather the Comp Cams or the Thunder Racing will work fine in there. I paid $110 for my TR pushrods.
Old May 28, 2004 | 10:39 PM
one03sierra's Avatar
Formerly one92rs
Talking
i am running these 01.
http://www.sdpc2000.com/cart.asp?act...1994&pid=81505
Old May 28, 2004 | 10:45 PM
ThunderZ28's Avatar
12 Second Club
yeah I was really wanting to stick with comp, but was seeing what if any was everyone else using.
Thanks for the info guys
Old May 28, 2004 | 10:52 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Originally Posted by 02denali
That's about as cheap as I've seem them anywhere! There you go Thunder right there.
Old May 28, 2004 | 11:48 PM
Mr. Sandog's Avatar
Someone at Thunder told me they get their chromoly pushrods from the same place Comp does, and that they're the same rods. Not sure if it's true, but that's what they told me.
Old May 29, 2004 | 01:49 AM
Flyer's Avatar
CC also grinds all the Thunder cams ..
Thunde, for what it's worth .. you should stick with an XE lobe (low lift) with those 1.85 rockers, because the XEr lobes will be brutal on the rest of the valve train.
Old May 29, 2004 | 03:31 AM
I'm with Flyer. Most cams with much lift recomend not using 1.8 or 1.85 rockers. What kind of setup do have in the works now. Tryin to get the 4.8 into 13s N/A?
Old May 29, 2004 | 10:44 AM
ThunderZ28's Avatar
12 Second Club
well I was looking at the xtreme RPM high lift cam on a 112 LSA
but was going to try and keep my valve lift under 550
figured this would keep me from hurting anything.
Futural had sugested a 208/212 as being my best choice, and a 210/214 being the biggest,both on a 113 l\s. Both cams will clear w\o any problems.
But I dont know and havnt been researching very hard.
but now I am looking and need to get this straightened out.
so what would be better a 112, or a 113 LSA.
Yes trying hard to get there, I really think I can do it by Aug.
Old May 29, 2004 | 11:04 AM
FILE's Avatar
Now that you mention it, they told me the same thing when I ordered mine. It was only a $10 difference between the two.
