need some info
Old Apr 17, 2010 | 10:42 AM
low_life96's Avatar
Default need some info
i orderd a 212/218 cam an gm yellow springs...... do i need pushrods or can i use stock ones?? an are the gaskets resuable??
Old Apr 17, 2010 | 12:03 PM
chiliz666's Avatar
By any chance how much did it run you? I'm thinking of going the same cam and springs
Old Apr 17, 2010 | 06:00 PM
low_life96's Avatar
springs were like 75 cam was 375 nelson tune was 300 got em for texas speed
Old Apr 18, 2010 | 12:09 AM
low_life96's Avatar
Old Apr 18, 2010 | 05:39 PM
low_life96's Avatar
Old Apr 18, 2010 | 06:23 PM
dirt track racer 81's Avatar
When I had that cam I ran the stock pushrods, its best to have better pushrods, but you can always put those in later down the road. all gaskets are re-usable.
Old Apr 18, 2010 | 06:35 PM
budhayes3's Avatar
PT's Slowest Truck
I always recommend hardened pushrods, but if money's tight and you're in a pinch you can get by with the stockers
Old Apr 18, 2010 | 06:39 PM
fastnblu's Avatar
What are other specs? Is this a Comp Cam?
Is this the cam?
http://www.compcams.com/Cam_Specs/Ca...csid=1085&sb=0
Tyler, stock pushrod length on this cam or longer? Or what I believe is the 1 OP is using. 7.4" or is it 7.350", I gotta be somewhat close.
Old Apr 18, 2010 | 07:07 PM
low_life96's Avatar
its Comp Cams XR265HR-14 Camshaft - 212/218 .522"/.529" 114LSA
Old Apr 18, 2010 | 07:09 PM
budhayes3's Avatar
PT's Slowest Truck
Is this the cam?
If the heads are untouched, you'll want 7.4's Stock is 7.38 btw
