Need some help,truck running crappy
Old Jan 24, 2010 | 05:50 PM
LsxCody's Avatar
Default Need some help,truck running crappy
well when driving the afr will jump around,and the temperature gauge will jump around too,truck will jerk around.it did this before and ive replaced engine coolant sensors and every few months it will start again. could it be something else,i got a new sensor in there today and it didnt fix it at all. any help
thanks
Old Jan 24, 2010 | 05:54 PM
00ChevyScott's Avatar
Wearin' da big hat
Can you go into more detail on the coolant temperature jumping around? How quickly is it moving and have you checked its accuracy with a scan tool?
Could be the water pump getting ready to go out or a blocked up radiator if it is fluctuating slowly.
Old Jan 24, 2010 | 06:02 PM
LsxCody's Avatar
its jumping fast,very fast will jump up to 250 then all the way to cool,does this very fast. ive replaced the coolant sensor like 4 times,every time i did it would fix the problem for awhile then come back.but today when i put a new sensor in it just kept doing it
Old Jan 24, 2010 | 06:03 PM
LsxCody's Avatar
and the truck will jerk alot every time the temp hand jumps down,im guessing its adding too much fuel
Old Jan 24, 2010 | 06:04 PM
Wearin' da big hat
Have you checked it with a scan tool? Could be the cluster going out.
Old Jan 24, 2010 | 06:08 PM
LsxCody's Avatar
no i havent checked it with a scan tool,if the cluster is going out would that cause it to add fuel like that,and make the truck run crappy
Old Jan 24, 2010 | 06:10 PM
Wearin' da big hat
No, the cluster has nothing to do with that.
Old Jan 24, 2010 | 06:17 PM
LsxCody's Avatar
i didnt think so, i wouldnt think all the sensors im buying are bad ones lol,then again they are advance and autozone brand crap
Old Jan 24, 2010 | 06:20 PM
Wearin' da big hat
Temp sensor probes rarely go bad. They're such a simple design that there really isn't much that could go wrong with them. The PCM gets signal from it in the form of voltage change or ohm resistance, so you might have some electrical noise or a bad wire somewhere causeing it to read funky.
Old Jan 24, 2010 | 06:32 PM
LsxCody's Avatar
has anyone ever had this problem,where should i look for the problem
