Need some help,truck running crappy
well when driving the afr will jump around,and the temperature gauge will jump around too,truck will jerk around.it did this before and ive replaced engine coolant sensors and every few months it will start again. could it be something else,i got a new sensor in there today and it didnt fix it at all. any help
thanks
thanks
Can you go into more detail on the coolant temperature jumping around? How quickly is it moving and have you checked its accuracy with a scan tool?
Could be the water pump getting ready to go out or a blocked up radiator if it is fluctuating slowly.
its jumping fast,very fast will jump up to 250 then all the way to cool,does this very fast. ive replaced the coolant sensor like 4 times,every time i did it would fix the problem for awhile then come back.but today when i put a new sensor in it just kept doing it
Temp sensor probes rarely go bad. They're such a simple design that there really isn't much that could go wrong with them. The PCM gets signal from it in the form of voltage change or ohm resistance, so you might have some electrical noise or a bad wire somewhere causeing it to read funky.
