need rod bolt help asap
Old Mar 22, 2009 | 09:27 PM
RickLowpez's Avatar
Default need rod bolt help asap
as we where putting rod bolts on a lq9 bottom end we took a bolt off which came with the thread insert to the rod cap. not the the rod thread. does this mean a need a rod cap ? cause i put a arp rod bolt and it still graps and tightens with the rod thread only?need help asap on any one with expierience on this issue. thanks
Old Mar 22, 2009 | 09:58 PM
budhayes3's Avatar
PT's Slowest Truck
Is it like a little sleeve? I thought that I read somewhere that you're supposed to remove those when installing ARP rod bolts anyway?
Old Mar 22, 2009 | 10:04 PM
RickLowpez's Avatar
yup looks lke a little sleeve. but the other rods nothing came we just put them in thanks
Old Mar 22, 2009 | 10:18 PM
RickLowpez's Avatar
so i pull the rod cap sleeve/threads off and only use the rod thread 4 the arp rod bolts right?
Old Mar 22, 2009 | 10:19 PM
Derek @ EDO's Avatar
FormerVendor
The sleeves need to be removed prior to installing the new bolts.
Im confused what your calling " rod thread"
Just removed the threaded inserts and install the new bolts.
Old Mar 22, 2009 | 10:27 PM
RickLowpez's Avatar
well on the bottom of the pistin rod it has a cap right? which the bearings go on 2 the crank . so the rod caps is where the rod bolts go. well on the cap side it has threads and on the piston rod also . from my understanding u pull the threads off the rod caps before putting arp bolts in?
Old Mar 24, 2009 | 03:32 AM
CashDudeHomie's Avatar
You have to pull them all out. Half of them will come out with bolts and half will be stuck. Just use a screwdriver or similar tool to carefully remove them. If you leave them in, the new bolts will not torque and stretch properly.
5.3Okasai
Mar 9, 2022 01:07 PM
greedygenius
Sep 3, 2015 06:51 AM
Yohns Kustom Fab
Aug 25, 2015 06:53 AM
Jake75
Aug 5, 2015 01:26 PM
Ammadien
Jul 22, 2015 08:50 PM
