Need a quiter exhaust
Old Jul 18, 2011 | 11:04 PM
overdrive's Avatar
Default Need a quiter exhaust
My son has a turbo'd 6 liter that we have a straight thru Neslon 4" exhaust that is dumped in front of the rear axle. It is way too loud. We use to have it turned out in front of the rear wheel, but it had a wicked popping to it when accelerating.
What muffler are you guys running that will flow enough but not require you to wear earplugs to drive it?
Old Jul 19, 2011 | 12:55 AM
rjwz28's Avatar
Man Motor club
Dumping it doesn't help the situation; it will at least seem more civilized if you run it to the bumper or at least over the axle. Honestly the factory 6.2 muff (3.5") is a decent piece, but any chambered muffler with a decent-sized body should calm it down from the racket your experiencing with a straight pipe.
Old Jul 19, 2011 | 12:56 AM
rjwz28's Avatar
Man Motor club
Dumping it doesn't help the situation; it will at least seem more civilized if you run it to the bumper or at least over the axle. Honestly the factory 6.2 muff (3.5") is a decent piece, but any chambered muffler with a decent-sized body should calm it down from the racket you're experiencing with a straight pipe.
Old Jul 19, 2011 | 02:11 AM
06Sierra2's Avatar
i bought the biggest magnaflow i could find....i think its the 22in one?
Old Jul 19, 2011 | 07:46 PM
overdrive's Avatar
Exhaust is 4", I want to keep it that size for the flow. Truck is also lowered--not much room to go over the axle with 4".
Might try to find an older system from a duramax and see it we can thread it over the axle.
Old Jul 20, 2011 | 02:03 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I modded a 4" D-Max kit from AFE for my truck. It sounds great, but it is INCREDIBLY loud, and drones terribly.
I know a turbo SSS guy from Fairbanks that says he used a Magnaglow 4" muffler, and a universal 4" mandrel bend kit, and while his truck is loud, it's not "as loud" and it doesn't drone nearly as much as mine.
Old Jul 20, 2011 | 02:30 AM
Mangled03gmc's Avatar
Baltimore Whore
I am running a 4'' edelbrock diesel muffler. It is loud, but does not drone to bad, you can still talk in the cab at light throttle. I have it over the axle, dumps rite behind the bumper. I also added a dynatech baffled tip to it.. It calmed the cracking down a bit..
Old Jul 20, 2011 | 02:56 AM
I'd like some info on the Dynatech baffled tip, so I can compare it to what I have.
Thanks!
Old Jul 20, 2011 | 04:59 PM
TimDave217's Avatar
Sounds almost like its impossible to get the exhaust down to a decent noise level
Old Jul 20, 2011 | 05:20 PM
overdrive's Avatar
I've got a 51" Donaldson on my Cummins, but I can't seem to make one of those fit under the chevy.
