Need to Know what Pin??
Old Dec 21, 2006 | 08:03 AM
phatboy's Avatar
Default Need to Know what Pin??
What pin is it for the fan control and how to go about locating it. Are the pins numbered or what? some detailed info would help alot , im installing flexalites this week and would really like the computer to control them.
Old Dec 21, 2006 | 11:38 AM
budhayes3's Avatar
PT's Slowest Truck
If I remember correctly, it's gonna be either pin 41 or 42...can't remember if it's the blue or red connector though. If you search for "efans", I'm sure the info will pop up. The pcm has to be tuned to turn the fans on, so if you're having it done by someone (Nelson, W4M, PCMforLess, etc), you should ask them which pin they use, and if it's the red or blue connector). There are little numbers on the connectors if you look closely.
Hopefully someone who know's/remembers will chime in with more info.
Old Dec 21, 2006 | 11:56 AM
Nick™'s Avatar
pin 42, blue connector
Old Dec 21, 2006 | 12:13 PM
nonnieselman's Avatar
Is Pin 42 on the Blue connector a +12v or a Ground "switch?
So if i were to wire my Efans up, i would put the wire that i now have goin to the mini switch there to activate the Relay?
Old Dec 21, 2006 | 01:44 PM
phatboy's Avatar
i beleive the wire goes to ground. hp tuners ? if you turn the fans on and flash the computer is that pin automatically activated?
phatboy's Avatar
thanks nick for the info!!
Old Dec 21, 2006 | 01:48 PM
Nick™'s Avatar
your welcome
in HP Tuners select "Aux. Fans", then go below that and set the Fan 1 temp settings how you like them, probably on ~210 and off ~192
the PCM gives a ground switch to the PCM pin for the fans, the A/C is a 12V+ trigger
Old Dec 21, 2006 | 01:57 PM
phatboy's Avatar
thanks again!
Porscharu914
14
Jan 20, 2016 10:45 AM
Silver8ado
Sep 30, 2015 11:42 AM
trxmxzx
Sep 29, 2015 07:42 AM
kalikid06
Sep 20, 2015 07:46 PM
99bluefirebird
Sep 17, 2015 08:05 PM
