need input
Old Sep 22, 2007 | 04:52 PM
knuckles's Avatar
Default need input
my engine is getting close to being done it is 405 ci and 10.5:1. i have 243 heads stock int. long tube headers. tb is ported along with maf. have k&n cai. thinking about the lunati voodoo cam 212in 218 exh .531 lift. what do you think and what kind of power do you think i will get.
Old Sep 22, 2007 | 04:56 PM
912jonathon's Avatar
looks kinda small to me
Old Sep 22, 2007 | 06:50 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
That is a tiny cam for a big in. 405. We have a more than a few members with 400+cu" engines, I'm sure they'll chime in shortly.
Old Sep 22, 2007 | 06:52 PM
knuckles's Avatar
yea but dont want to mess with trans or converter yet and i want more low end power and i dont want to spin it over 6000 rpm
Old Sep 22, 2007 | 06:54 PM
knuckles's Avatar
also later would like to boost it
Old Sep 22, 2007 | 07:03 PM
trever1t's Avatar
Lol, my cam is bigger than that on my blown 5.3L
What trans?
Old Sep 23, 2007 | 01:16 AM
knuckles's Avatar
el60 trans, what cam are you running and does it required a stall converter
Old Sep 23, 2007 | 01:25 AM
knuckles's Avatar
also where in so cal can i get a good tune
Old Sep 23, 2007 | 06:23 AM
you went 10.5.1 comp and want to add boost later?
Old Sep 23, 2007 | 09:51 AM
trever1t's Avatar
This is the cam I run on a 5.3L it is too small for your application. BTW 10.5:1 CR is do-able for FI but most like it down around 9-9.5:1
Cam Number Duration @ .050 Valve Lift Rocker Arm Centerline
LS1-GT2-3 207 / 220 .571" / .578" 1.7 ratio 118.5
I doub't even a fully built 4l60e is ever going to hold up to a built 400+cu" engine. You aren't going to get too far with it. You really need to look at the big picture and decide on what direction you want to take it or you will end up throwing $ out the window.
