need help..v6 to 6.0 swap/ 4.8 to 6.0 swap
Old Mar 24, 2009 | 12:31 PM
TwoFast's Avatar
Default need help..v6 to 6.0 swap/ 4.8 to 6.0 swap
I've searched but I havn't found what I'm looking for...What all would I need to convert a 99-02 v6 auto truck to a v8 truck? will i need to change motor mounts and cross member and rear end? I know the 4.8/5.3 to 5.7/ 6.0 swap is easier but what all is needed when starting with a v6 truck?
Old May 29, 2009 | 01:23 PM
dropped4dohoe's Avatar
done it and its a pain in the ***. i used v6 mounts but better to use v8 and brackets to crossmember they just go in opposite sides. using v6 mounts motor is pushed back couple inches so driveshaft is shortened. got a painless harness and 02 ecu to run motor and original harness and ecu to run stock gauges. also rebuilt v6 trans with some v8 components. its an 06 truck with a 6.0 and 5.3 heads cammed and stalled. runs good but wasnt fun swap. was done year and half ago.
Old May 30, 2009 | 07:17 AM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
http://www.ls1truck.com/forums/mecha...gine-swap.html
and your welcome
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
JordanH
Aug 8, 2015 07:59 PM
Suburban2500
Jul 19, 2015 04:50 PM
