Need help/suggestions/tips on trying to find an intake leak
Old May 28, 2008 | 12:49 PM
BlackGMC's Avatar
Resident Retard
Default Need help/suggestions/tips on trying to find an intake leak
A buddy of mine is having a fuel trim problem and the tuner thinks it is either a intake leak or low fuel pressure.. So we are going to try and find the leak today, any tips/suggestions/advice to finding a intake or vacuum leak?
I was thinking of hooking up my laptop and logging idle fuel trims, STFTs and LTFTs and then hose the intake down with carb cleaner and seeing if the trims change... Sound like a decent idea??
Old May 28, 2008 | 01:00 PM
thunder550's Avatar
High on diesel fumes
That's what I would try first. I've heard (never experienced) that you'll be able to hear a change in the engine sound as well when you do that.
Old May 28, 2008 | 01:02 PM
CurtD's Avatar
10 Second Truck Club
You should be able to spray some in specific areas ( like by 1/3, 2/4, 5/7, 6/8) and the idle will raise . That way you get a better idea where the leak is.
Old May 28, 2008 | 01:04 PM
BlackGMC's Avatar
Resident Retard
Thanks guys, we will give it a shot this afternoon, hopefully we find the leak...
Old May 28, 2008 | 01:06 PM
2005 Silverado's Avatar
SPAM HUNTER
Old school, use a burnable gas around the intake, and listen for the motor or rev up...i hears it dangerous, but oh well!
Dustin
Old May 28, 2008 | 01:08 PM
BlackGMC's Avatar
Resident Retard
Dustin
Mmmmmm, I think I will pass on pouring gas on a hot engine...
Old May 28, 2008 | 01:11 PM
SPAM HUNTER
No like a gas gas, not liquid gasoline, like a butane torch (not lit of course)
Dustin
Old May 28, 2008 | 01:30 PM
BlackGMC's Avatar
Resident Retard
Dustin
Ahhh, that makes a little more sense....
Old May 28, 2008 | 02:06 PM
53RUSSELL's Avatar
When my intake was leaking long fuel trims were max out at 25%. Try tightening up the intake bolts 1 or 2 turns see if the Long fuel trims go down. I just replace the gasket and it solves my problem.
budhayes3's Avatar
PT's Slowest Truck
Carb/intake cleaner is what I've always used...
