Need Help PLEASE...
Old Aug 22, 2011 | 09:25 AM
2ksschevy's Avatar
Registered User
If you guys were in my situation what would you guys do? I feel like my trucks exhaust doesnt flow rite for some reason even when its in park and i rev it its not loud at all and when i drove it all i can hear is a bunch of air coming from the engine area.....
WHAT SHOULD I DO?????? Im thinking of putting the stock headers back on
Old Aug 22, 2011 | 11:54 AM
budhayes3's Avatar
PT's Slowest Truck
Well, the headers themselves won't make the exhaust note all that much louder, especially if you're still rocking the stock muffler, and the air that you're hearing in the engine bay is from the AIR pump, which is just pumping fresh air out of the two ends of the air injection pipe.
Just an FYI, if you don't have other mods such as a cam or headwork, you probably won't notice much of a power increase from the long tubes until you get higher up in the RPM's. Many guys actually report a loss of power down low, as the bigger exhaust primaries and collectors will allow for more flow, but slow down exhaust velocity and scavenging and may be overkill for a basically stock setup that sees most of it's operation in the low to mid range.
My biggest concern, if I were in your situation, would be the smog police. I would look into some mid lengths that allow you to retain the stock catalyst location and are CARB approved...I believe that Doug Thorley or just Dougg's headers make mids. If nothing is available along those lines, I'd get some shorties as they are your only other choice. I know that most of us frown upon shorties, and I can tell you that I didn't feel any gains back when I had mine, but they usually are worth 5 to 10 rwhp and are better than nothing. I know that there are shorties available with EGR and AIR provisions...back when I bought my stainless Gibson shorties (like 10-11 years ago), those were options.
Maybe ask the shop that did the welding how their other customers get by with long tubes. I'm sure that the headers could be modified to accept the AIR fittings, and you could do a yearly swap for state inspection, I'd mainly be concerned about the spot inspections that the smog ***** subject you to
Old Aug 22, 2011 | 11:58 AM
AJII's Avatar
So they are just there he said he couldnt do anything about them and gave me my keys and said its going to be $500
Am I reading this correctly...he charged you $500 for the INSTALL?
Old Aug 22, 2011 | 12:06 PM
budhayes3's Avatar
PT's Slowest Truck
I wonder if the price is excessive since they're not supposed to be doing those sort of installs in Cali? Not to mention that the guy was cutting and welding to get the PaceSetters to adapt to the factory y-pipe...
Old Aug 22, 2011 | 12:19 PM
Sc00by's Avatar
That's AIR injection which is an emissions device. There is an air pump (top of picture, between left and center) which pumps fresh air into the exhaust stream to help burn unburned exhaust gasses that have escaped combustion. You can remove the AIR system and have it tuned out via software like EFILive or HPTuners, but I notice that you're in CA, and removing emissions equipment like that is a big no-no there. Honestly, I'm not sure how you'll pass smog with the LT's in the first place being that you're in Cali.
Sounds like a bunch of tree hugging hippy crap to me.....
Old Aug 22, 2011 | 01:28 PM
hog's Avatar
hog
It wouldnt be difficult to get a couple AIR fitting welded into a primary of each header.
This link shows an EGR and AIR fitting onto a set of Hooker longtubes for use in California.
GM Performance :: View topic - Driver-Side SuperComp mods finished.
peace
Hog
Old Aug 26, 2011 | 09:49 PM
2ksschevy's Avatar
Registered User
Thanks again for your comments guys.... Well the headers are still on i capped off the valves but it still dont sound makes my XR-1 sound like **** it also feels like the exhaust has no power on the way out. The only good thing is that i havent gotten a check engjne light.
@ AjII yup $500 the price for performance add ons is crazy i asked around a couple of shops and a tune will cost me$ 5-550 re-tune 250 and it all depends on what mods. I went to 3 shops to ask about a vette servo and the best price i got was $220
Now i know why a bunch of trucks in my area are ALL SHOW AND NO GO!
Old Aug 27, 2011 | 01:23 AM
06Sierra2's Avatar
get a tune from blackbear or another sponsor instead of a local shop. and i bet after reading the sticky you could do a vette servo yourself, its a cheap, easy, and very worthwile mod.
Old Aug 27, 2011 | 10:50 AM
Beatdown Z's Avatar
Laid Back
Sexy truck man! What drop you have on it? That color is Carmine Red, right?
Old Aug 27, 2011 | 10:58 AM
letsrun97z's Avatar
For sure get a mail order tune it will come alive. I got one on my truck and it woke it up and I am all stock
