Need help with piston to valve clearance
Old Oct 26, 2005 | 05:45 PM
Dark Halo's Avatar
Default Need help with piston to valve clearance
I have just got in a set of Patriot performance stage 2 LS6 heads with a 64cc combustion chamber 2.02 intake, 1.57 exhaust. My cam is a comp cams 230/236 @ 50 .591/601 110lsa. I am wanting to know if I will have any clearance problems on a 02 LQ9?
Old Oct 26, 2005 | 06:28 PM
Yellowsierra's Avatar
No you shouldnt have any clearence problems. If you want to check the clearence out you can put some playdoe on the piston then put your heads back on spin the motor over by hand take the heads back off than check your clearence. I know it takes alot of work to just check the clearences but its beter than smacking a piston with the valve.
Old Oct 26, 2005 | 07:10 PM
Dark Halo's Avatar
my only problem right now is the pistons are not even in the block yet. I am looking for a rebuild kit for the motor. How can you tell how much clearance you have with the clay? What do you messure it with?
Old Oct 26, 2005 | 07:35 PM
erronisme's Avatar
The thickness of the playdoe....
If the valve goes through the playdoe or almost through the playdoe then you will probably have some contact...
If there is still a good bit of playdoe between where the valve was then everything will be fine
well worth the check
Old Oct 26, 2005 | 07:36 PM
02sierraz71_5.3's Avatar
hhhmmmmm 402??????? you know you want to do it
Old Oct 26, 2005 | 07:49 PM
Dark Halo's Avatar
I have 2 6.0's. My other block will become a stroker later on
FlyingLow
Nov 24, 2015 10:05 AM
zblee
Nov 11, 2015 12:41 AM
11MPG
Sep 8, 2015 04:52 AM
bisqikss
Sep 8, 2015 03:35 AM
