need help on my 5.3 project
Old Jul 16, 2008 | 10:37 PM
J.Garcia's Avatar
Question need help on my 5.3 project
i got 2 5.3 laying around in the garage and the one on my motor i was wondering if a 4.00" crank will fit in it with no problem and if i could bore it out to a 4.00"(6.0) with no problem and i want a cam to go with it but somethng that will make it work like crazy got some stage 3 heads to go with it from texas speed
Old Jul 16, 2008 | 10:40 PM
InchUp's Avatar
Max bore is going to be much less. Try 3.898" for starters, probably 3.905 maximum before you're at minimum wall thickness. You can successfully make a 383 out of your 5.3L with that 4" crank. Have a machine shop sonic test the block(s) before boring over. I ended up being at minimum wall thickness on two of the cylinders after boring to just 3.898".
Choda
Jan 22, 2026 02:03 PM
Vash3233
Sep 22, 2019 01:18 PM
Zizzle
Oct 19, 2017 08:44 PM
JordanH
Aug 8, 2015 07:59 PM
vmaxpro
Jul 27, 2015 10:45 PM
