need help with guages
Old Dec 6, 2003 | 04:33 PM
goshawk23's Avatar
Truck addict
Unhappy need help with guages
coming home from work today and my speedo dropped from around 60mph to about 30 and then bounced back up, then my tach started bouncing around. i thought ok, wierd. well a little further down the road i looked again and the speedo was over on 100 and the tach was on zero. my temp gauge looked off as well as my volt meter. i had no gear selecter lit up and the other square info center was not working. anyone have any clue as to what could be causing this. i checked a few fuses in the cab and they looked good. could it be a fuse under the hood?
Old Dec 6, 2003 | 05:06 PM
blacksheep's Avatar
You may want to check the alternator, truck did strange things kinda like that when the alternator went out.
Old Dec 6, 2003 | 05:36 PM
Flyer's Avatar
Check the plug that goes into the cluster too. Pull the fascia thing off, then 4 bolts that hold the cluster in. The bolts are 7mm and the fascia just snaps in place.
Old Dec 7, 2003 | 03:29 AM
goshawk23's Avatar
Truck addict
i will check both when i get up tomorrow. thanks for the help.
Old Dec 9, 2003 | 12:59 AM
goshawk23's Avatar
Truck addict
gauges fixed, was the plug that connects to the inst panel. guess when i added my white face insert a while back i didn't plug it in all the way.
Old Dec 9, 2003 | 01:56 AM
Flyer's Avatar
I had one wire on mine that started getting buggy. I would have to hit the dash going down the road sometimes. My gauges would just 0 out though.
Lthompson
Oct 2, 2015 12:45 AM
Lthompson
Sep 21, 2015 07:06 PM
Lthompson
Sep 15, 2015 07:55 PM
wrb002
Aug 25, 2015 03:56 PM
tgui
Aug 22, 2015 12:08 PM
