need help with guages
coming home from work today and my speedo dropped from around 60mph to about 30 and then bounced back up, then my tach started bouncing around. i thought ok, wierd. well a little further down the road i looked again and the speedo was over on 100 and the tach was on zero. my temp gauge looked off as well as my volt meter. i had no gear selecter lit up and the other square info center was not working. anyone have any clue as to what could be causing this. i checked a few fuses in the cab and they looked good. could it be a fuse under the hood?
wrb002
Aug 25, 2015 03:56 PM
