Need help finding intake vacuum leak
Old Aug 16, 2010 | 07:45 PM
nickleahy23's Avatar
Originally Posted by oldred95
I was going to suggest smoke testing it for a leak but someone beat me to it. Interesting place to find a vacuum leak but its sealed none the less.
Here is what I've found on the 4.8, 5.3,s and 6.0s as far as oil leaks go. The most common leak is the rear of the oil pan gasket. This seems to happen on 05+ engines the most although a handful of early 6 liters have a tendency to leak there too. A rear main leak isn't really all that common unless your bearings are wasted and by that point you'll know something is up. The other leak is the rear engine cover. I've seen some that were porous and the oil just leached through the casting and on some that oil was leaking out around the bolts due to a bad gasket. I put one on a 01 6 liter and got the timing cover, gasket, bolts and rear main already installed as an assembly for 66 bucks. You can't piece it all out for that. Put it on and no more leaks. The last leak is the oil pressure sender. Just because it works doesn't mean it doesn't leak.
thanks man...just sucks id have to pull the trans to get to any of it..i might call up the trans shop that did the rear main and tell them its leaking again and see what happens..they said everything is covered, so even if they pull it and find out it isnt the rear main, all i would have to do is pay parts to put in a new gasket somewhere..
id say it might be the oil pan, but its higher up on the block (i think)...im going to clean it up real good and then go from there and see what i can find
Old Sep 1, 2017 | 02:38 PM
Trevor Mumby's Avatar
Registered User
Originally Posted by nickleahy23
After talking with justin when he took a look at my logs, he said I have a major intake vacuum leak, since my IAC is pretty much closed the entire time the motor is warmed up..
I checked the TB gasket, both sensors on top of the intake, plug for EGR, and all seemed fine. I couldnt feel anything around the brake booster or back of the motor where the line comes in.
Im thinking my next step is to pull the intake and re seal it. Any tricks to this? basically just unhook everything, 8 bolts that hold the intake down and go from there? Can I get new seals for it, or do I reuse what is on there?
I do have an oil leak from somewhere on the back of the motor, but im guessing that couldnt cause a vacuum leak anywhere right?
What was your truck doing when it had the vacuum leak? My truck will rev up to like 2000rpm and hold it there for a few seconds when I put it from drive to park or neutral and will sometimes almost die while sitting at a stoplight in drive and I'm thinking mine may have a vacuum leak as well but I'm not sure.
05GMC4.8
Aug 7, 2015 09:55 PM
1320Chicken
Jul 14, 2015 10:58 PM
Blackrat48
Jul 12, 2015 07:28 PM
Hmguyton
Jul 7, 2015 03:29 PM
