Need help with clearances
Old Aug 18, 2005 | 05:01 PM
12sec.5.3's Avatar
Default Need help with clearances
I should be ok but can someone help me figure this out? I want to make sure I have enough piston to valve clearance. lq9(flat top), milled .020 off heads, .588 lift, stock length pushrods.
Old Aug 18, 2005 | 09:45 PM
litreddevil's Avatar
Banned
todd you will be fine i have the lqa with soild lifters and my lift 584 on exhust and when i checked it witch i did 2 ways first i did it with clay and came up with 108 ths clearance and then i put the valve to full lift thenback the nut off the rocker and counted the tuns then put 110 ths shims between the rocker and head ofthe valve and counted the turns back down and still had 1 1/2 extra turn.
u will be fine
Old Aug 19, 2005 | 11:17 AM
12sec.5.3's Avatar
Thanks
Old Aug 19, 2005 | 12:47 PM
BigTex's Avatar
Duration of the cam and LSA plays a big part in that equation as well. If its a big wide cam, it may or may not have the valves closed soon enough. I doubt that you'll have problems unless you are running something silly like a 244 duration cam.
Old Aug 19, 2005 | 02:49 PM
12sec.5.3's Avatar
Ok thanks BigTex. The duration is in the 22x's. lsa will be 112.
zblee
Nov 11, 2015 12:41 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
LSX-81-SIERRA
Sep 5, 2015 02:51 PM
