Need help... broken sensor.
Old Oct 17, 2005 | 11:48 PM
12sec.5.3's Avatar
Default Need help... broken sensor.
First, It's been a while since I've been here because of so much going on. My pulled the 5.3 yesterday and dropped in the 6.0 about 2 hours ago. There are 2 sensors threaded into the block near the firewall. I believe one is cam position and other is oil pressure. The oil pressure sensor was cracked during all the comotion so i now need a new sensor. The one that came with the 6.0 is smaller and only has 1 pin compared to the old one has 3 pins. I managed to get my hands on the plug for the new type sensor also. Problem is, will the 3 pin sensor work with only 1 wire hooked to it? Or do I need an older style sensor? Thanks in advance.
Old Oct 17, 2005 | 11:54 PM
99Silver6.0's Avatar
I had the same issue on my 99 kinda. The 03 6.0 had a newer 3-wire sensor. I ended up breaking the tall 1-wire sender on my 5.3. I just put the 6.0 sender in till I got my new one. Better off getting the right sensor man. From what I can tell you need the tall sender, PN 12562267.
Old Oct 18, 2005 | 12:04 AM
12sec.5.3's Avatar
Thanks man. Is that the gm part #? If not, where do I get it?
Old Oct 18, 2005 | 11:08 AM
budhayes3's Avatar
PT's Slowest Truck
Yea, that's a GM part number...try it out on GMPartsDirect.com and it should come up. If you swing by your local dealer with that PN they *might* even have the part in stock.
Velocity1
Oct 2, 2015 08:01 AM
Wrecker 426
Sep 30, 2015 09:39 PM
Blklgt
Sep 28, 2015 03:21 PM
trevorh1
Sep 27, 2015 08:47 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
