Need help... broken sensor.
First, It's been a while since I've been here because of so much going on. My pulled the 5.3 yesterday and dropped in the 6.0 about 2 hours ago. There are 2 sensors threaded into the block near the firewall. I believe one is cam position and other is oil pressure. The oil pressure sensor was cracked during all the comotion so i now need a new sensor. The one that came with the 6.0 is smaller and only has 1 pin compared to the old one has 3 pins. I managed to get my hands on the plug for the new type sensor also. Problem is, will the 3 pin sensor work with only 1 wire hooked to it? Or do I need an older style sensor? Thanks in advance.
Yea, that's a GM part number...try it out on GMPartsDirect.com and it should come up. If you swing by your local dealer with that PN they *might* even have the part in stock.
Wrecker 426
Sep 30, 2015 09:39 PM
