Need Help ASAP!!!Engine won't turn over!
Old Jan 4, 2007 | 09:57 PM
14 Second Truck Club
Default Need Help ASAP!!!Engine won't turn over!
Got everything hooked-up on the new motor today. Turned the key over several times without cranking it to build fuel pressure. Went to go start it and it wouldn't turn all the way over. Sounded like the battery was weak, so I charged the batter for about an hour, nothing. Rolled the truck down the driveway and tried to jump start it for about 30min., nothing. Went to Wal-mart and bought a brand new battery, nothing. Then I found a ground wire on the back of the block on the passanger side that I must have overlooked. Bolted it down to the back of the head. Nothing.
Is it possible that I flooded the motor trying to crank it so many times?
Could I have blown a fuse when the ground was disconnected? The other ground wires on the driver side ARE hooked up.
Anybody know of any ideas? Please help!!!
Old Jan 4, 2007 | 10:00 PM
LesPaul's Avatar
you cant "flood" that motor...... i would check all wiring and fuses... i know i missed a few when i did mine..... had some starting issues
RoosterMcCandles's Avatar
I would check all of your fuses and wiring first...
Old Jan 4, 2007 | 10:06 PM
Is there certain fuses I should be looking for? Or just pop the fuse cover and check them all?
The ground strap on the firewall goes to the back of the block, right?
Should I take out the spark plugs or anything?
In the morning I'm gonna check everthing that I can, just trying to get as many ideas for tomorrow as I can. Thanks for any suggestions, keep 'em coming!
Old Jan 4, 2007 | 10:26 PM
Zick's Avatar
Check the ground strap on the side of the block, drivers side. I had hell of times starting my truck when this strap wasn't grounded all the way.
Old Jan 4, 2007 | 10:33 PM
Does it go on the block, head or either?
Old Jan 4, 2007 | 10:34 PM
Zick's Avatar
Mine bolts into the bottom side of the block. Pretty much right behind the power steering pump.
Old Jan 4, 2007 | 10:38 PM
Zick's Avatar
Right in this area where I circled red. Sorry, best picture I had.
Is there 4 grounds, two on each side? Front and back?
Old Jan 4, 2007 | 10:40 PM
Zick's Avatar
I only remember 2 on mine. One on the back of the heads, and the one on the bottom side.
