Need Help ASAP!!!Engine won't turn over!
14 Second Truck Club
Originally Posted by Zick
Right in this area where I circled red. Sorry, best picture I had.
WHere does the braided strap on the firewall go? I put it with the other ground strap on the back of the head.
Originally Posted by Hemi Killer
Thanks for the picture! Yeah, I remember doing that one. I'll double check it though.
I'm pretty sure it went to the back of the head.
Actually going through some of my pictures it looks like there should be one ground strap on the back of each head. The passenger side has a smaller ground strap.
Does the dash and eveything else work? but the starter wont turn over? On mine the headers have heated the wire that tells the starter solinoid to engage and made it brittle. if everything else works and the starter wont turn, look at this wire....Good Ruck
I didn't reassemble everything with a ground strap to the passenger side, I need to look around, I might have overlooked it. Where does it connect to from the head?
Originally Posted by dirt_track_racer_81
i had the same problem and i had a heavy ground wire that went to the bottom of the block
I had 5 grounds total on my motor. Two (including the big one straight from the negative battery post) went to the lower driver's side of the engine block. One (the ground strap from the firewall) bolted to the driver's side of the block in between the heads at the back of the motor. Two more (one from the coil pack harness and one from somewhere else - maybe the tranny harness?) went to the passenger side of the block in between the heads at the back of the motor.
Pull the plugs out and try to turn ir over by hand with a breaker bar on the crank bolt. If it still doesnt turn over you have a mechanical problem in the engine. I've seen engines with improper deck clearance do this, as well as engines with cams installed wrong.
If it turns over by hand with no plugs, put the plugs back and try it again. It will be hard but it should still turn. The cam could be 180* out and be holding too much compression for the starter to turn over. Doubtful but possible.
