Need HELP ASAP
Old Oct 8, 2005 | 07:23 AM
Fogle07's Avatar
Default Need HELP ASAP
doing the cam swap in my truck today. i got most of it tore down but the braket that holds the alt. and ps pump i cant get it off. theres two bolts behind the ps pulley do i have to take the pulley off to get those out? last time i didnt have to do that i just cant remember how i done it. thanks in advance
Old Oct 8, 2005 | 07:49 AM
SSlow 4.8's Avatar
I'm trying to remember if i had to take off the alternator bracket or not.. i must have, the bolts wont budge? is thats whats going on?
Old Oct 8, 2005 | 07:51 AM
Fogle07's Avatar
i done took the alt off. the ps pump has two bolts behind the pulley you cant get off unless you take the pulley off
Old Oct 8, 2005 | 08:19 AM
greentahoe's Avatar
Are you having to do this to get the cover off? I Have a different bracket since mine holds my blower as well, but mine is bigger and all I had to do was loosen the bolts so that I could slide the cover off to get to the oil pump and cam
Old Oct 8, 2005 | 08:28 AM
Fogle07's Avatar
i havent tried to take the water pump off with that bracket on there. i just figured you had to take the bracket off in order to get to the bolts for the water pump. hopefully im wrong.
Old Oct 8, 2005 | 08:46 AM
quicksilverado's Avatar
If you get under the truck and look at the back sid eof the bracket there are 2 nuts that you have to take off. Or you can look where the 2 nuts are. They are on a smaller bracket. There is 1 bolt that holds it to the side of the engine block.
Old Oct 8, 2005 | 08:56 AM
Fogle07's Avatar
alright i got the waterpump off. now i need to get the bolt out of the crank. i just tried doing it with an impact and it didnt budge. anybody got any ideas?
Old Oct 8, 2005 | 09:07 AM
Fogle07's Avatar
nevermind i got the bolt out now all i got to do is get the pulley off if i can find a puller
Old Oct 8, 2005 | 04:39 PM
bluecajun5.3's Avatar
11 Second Truck Club
our motors must be different. i never had to take off alt and ps bracket's to take the water pump off.
Old Oct 8, 2005 | 05:01 PM
FarmerBeau's Avatar
Sexy Party Mod
ya man why are you having to take any of that off. i dont even think ls1s have to pull all of that off. when i do my swaps i dont even take the oil pump off.
