Need Help ASAP
Old Jan 31, 2004 | 10:49 PM
getsome's Avatar
Default Need Help ASAP
I am trying to install a cam but not sure how with the heads on it. How do you take the lifters out with the heads on it? Need all the info i can get for install.
Old Jan 31, 2004 | 10:52 PM
jrp's Avatar
jrp
SN95 Director
http://www.ls1howto.com/index.php?article=23
tear down is different but the cam/spring swap should be the same. and you cant remove the lifters without pulling the heads. but for a cam swap you dont need to pull heads.
Old Jan 31, 2004 | 11:00 PM
getsome's Avatar
Ya i am putting just cam and springs in. I just didn't know how i could keep everything up without falling down. I have the 14 mm thing to put in the spark plug hole to hold the valves up.
Old Jan 31, 2004 | 11:20 PM
jrp's Avatar
jrp
SN95 Director
Originally Posted by getsome
Ya i am putting just cam and springs in. I just didn't know how i could keep everything up without falling down. I have the 14 mm thing to put in the spark plug hole to week the valves up.
just uses the TDC method to hold the vavles up, thats the easiest way.
Pimpinpete
43
Dec 22, 2017 08:13 AM
GM1697
Sep 28, 2015 08:28 PM
MOBBN
Sep 22, 2015 08:07 PM
