Need help with 95 1500 trans....
Old Aug 23, 2002 | 04:46 AM
Jasonj478's Avatar
Default Need help with 95 1500 trans....
A friends got a 95 that won't shift past 2nd. It wouldn't shift at all until he changed the fluid and filter. When he changed the fluid he noticed had a bad front seal in the trans.
Whould that make it not change into 3rd?
What might be the problem?
How much to rebuild?
How much to buy a rebuilt trans?
Thanks
Thruck has 150K miles if it matters.
Old Aug 24, 2002 | 07:48 AM
Jasonj478's Avatar
Default Re: Need help with 95 1500 trans....
Little help? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Aug 25, 2002 | 01:57 PM
wrencher's Avatar
wrencher
Sounds like an overhaul is needed <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Its also a pcm contrlled tran = more $$. Have a trans shop check it out & maybe you'll luck out. If not some guys will rebuild if you r&r to save money. You are in the $1500 range for one of these r&i & o/h. Give or take a few . <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Aug 25, 2002 | 06:04 PM
Pro Stock John's Avatar
Registered User
The tranny in my 99 taHOE is slipping 2-3 and 3-4 and it's gettng redone for $1000 including install.
All my estimates were $1000-1500 FYI.
Might want to take it to a reputable tranny place and see if they can pull up codes... If it does not shift maybe an accumulater is bad.
dsbodley
Nov 14, 2015 09:46 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
zblee
Sep 17, 2015 07:58 AM
