Need Help With 4L80E Swap
Old Dec 29, 2004 | 06:44 PM
Jason 98 TA's Avatar
FormerVendor
Default Need Help With 4L80E Swap
Can you guys give me a little advice on a 4L80e swap in my 04 silverado. It's a cable less throttle setup so I'm not sure what I need to do as far as tranny control. How about install tips guys
Jason
Texas Speed
www.texas-speed.com
Old Dec 29, 2004 | 06:48 PM
Scream's Avatar
MOOBIES Moderator
Check out www.turbotruck.net. Jim has a lot of good information on his site. Maybe someday I'll get mine done and can give some real world advice to some peeps.
BTW...sent you a PM.
Old Dec 29, 2004 | 06:56 PM
Scream's Avatar
MOOBIES Moderator
Oops...look's like someone's exceeded their bandwidth for this month.
Basically, you need:
  • crank spacer & bolts
  • 6.0L flywheel
  • fabbed crossmember (the mount is farther back than the 60-e)
  • Speartech conversion harness & custom tuning (the truck PCM will control it, just needs the correct flash)
  • shortened driveshaft (although I've heard of some folks staying w/ the stock 60-e shaft, an aftermarket shaft would be a good idea for any high HP apps)
  • modified cooler lines
I'm also going w/ a Yank TT3200HD converter, although the PI triple disc units look really nice and probably what I would have gone with if they were out when I got my Yank. I'm also going w/ a Transgo shift kit and separator plate in mine, along w/ a huge-by-large tranny cooler.
Am I missing anything guys?
L-EATER's Avatar
11 Second Truck Club
You are going to hafta contact Speartech and get a file from a 4l80e equipped truck. I am not sure about the '03 and ups but I had a problem because no 01 or 02 trucks came from the factory with a 4l80 and ETC. I had to lose the ETC and go to a cable throttle.
Old Dec 29, 2004 | 06:59 PM
FormerVendor
Sounds good guys! I emailed Speartech already The 4.8l lived at 22psi but the 4l60 doesn't LOL I'm a little worried about the ETC & the 4l80e conversion. I really am leaning towards a cable throttle conversion, but don't really know all the tricks to make that work. My 04 always tried to pull away throttle at wot with high boost & it would drop 10psi+ when the computer tried to do it
Old Dec 29, 2004 | 07:00 PM
Scream's Avatar
MOOBIES Moderator
Crap...I didn't even think about that. So since my tranny is a 2003 and it's going into an 01, I'm gonna have to get the cables and all from a 2002 or older truck?
Old Dec 29, 2004 | 07:52 PM
L-EATER's Avatar
The hardest part of the throttle conversion is installing the pedal for the cable type system. You will need a TB, a TB harness (from Speartech), a cable, cable bracket to mount the cable to the intake, and a pedal assy. Then you will need a cruise control module, cable, and associated wiring (which Speartech did not carry when I did mine). Was a PITA but once the conversion is done, you will wonder why you didn't do it sooner.
Old Dec 29, 2004 | 08:48 PM
one03sierra's Avatar
Formerly one92rs
Talking
damn im glad i didnt have to do that. you will have to get the driveshaft or yoke or get one of them different size u joints on the driveshaft/
Old Dec 29, 2004 | 10:14 PM
Flyer's Avatar
You shouldn't have any issues with it being a fly by wire throttle. I didn't. The hardest part is fabbing the crossmember up.
I got a file from Speartech and uploaded it into my PCM and started editing. You will also need a wiring harness from Speartech to hook it up. Other than that, it's all plug and play.
I would advise getting a new driveshaft made though. The one you have now will work, but it needs a new yoke on the front (assuming you're in a 2wd and not 4wd).
Any other questions, PM me.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
chadjcompton
17
Jun 21, 2022 08:47 PM
XL7
May 5, 2022 01:48 PM
lycominghunter
Jul 29, 2015 04:24 PM
alex226
Jul 16, 2015 10:55 AM
