Need green keys help!!
Old Apr 2, 2005 | 07:06 AM
Layho75's Avatar
Default Need green keys help!!
This might be a rookie question. How do you install green keys for the leveling my truck out? Is this a need a lift or will a floor jack work? Need a fancy tool or a socket wrench work? I just need a book for dumbies. lol
Old Apr 2, 2005 | 07:15 AM
You need some 1/2" drive sockets and 1/2'\" drive ratchet. A little muscle too.
You will nedd floor jack that can lift pretty high. Or just use a spacer or something. Then you will need 2 descent highdth jack stands.
Jim
Old Apr 2, 2005 | 07:41 AM
Layho75's Avatar
Jim
Thanks for your help
But can I get pics of it already installed?
Old Apr 2, 2005 | 08:03 AM
htsht's Avatar
Banned
http://www.offroad-tech.com/tech/tb401/
Here is a link with some pics. Its not very hard to do. Did mine a couple weeks ago. Did mine with a 2 jaw gear puller not the GM torsion bar tool. It worked out just fine.
No pics here, but you will need to pick up your truck by your frame with floorjacks, then put your jack stands under your frame. let the floor jacks down slow. Your going to need the floorjacks to use under your rear diffential. Two floorjacks are preferred.
From there take off your tires to give you better access to work.
Then it's all you. Make sure you torque your bolts back to specs. (you will need a torue wrench too)
Sorry I do not have the torque specs.
An air impact or an electric impact will be of great help too.
Good luck!
Jim
Old Apr 2, 2005 | 08:11 AM
htsht's Avatar
Banned
Good luck!
Jim
Have to correct a few things there. You dont need to take the tires off nor do you need a torque wrench.
Jack up front end, use the gear puller or the gm tool and line up with dimple on keys. Put small amount of pressure on key, just enough to make sure it wont slide. Next remove the torsion bar bolt. Need a 18mm socket. Remove the flat threaded piece in there as well. You will see what I mean when you get to it. Next let preload off of key. Going to have to play with the key to get it off. Yours is pretty new, that should help you out some. I had to beat on mine a little to get the key loose.
Slide new key in. Load it back up with puller or GM tool. Install bolt and adjust to height you want it set at.
Old Apr 2, 2005 | 08:20 AM
Layho75's Avatar
thanks guys for your help, Hey where can I get the "GM tool"?
Old Apr 2, 2005 | 08:22 AM
htsht's Avatar
Banned
My dealer around here was going to sell it to me for $80. I am a tight *** so I didnt get it. The gear puller works really well.
Old Apr 2, 2005 | 08:29 AM
Layho75's Avatar
I found the website sorry!!
http://www.sjdiscounttools.com/otc7822a.html
Thanks for your help Guys!!!
Old Apr 2, 2005 | 09:20 PM
04BlackGmc's Avatar
10 Second Club
I would recommed the Torsion Key tool made my JOb alot easier.
