Need Exhaust Suggestion
Old Aug 30, 2011 | 11:14 PM
jvmorgan's Avatar
Default Need Exhaust Suggestion
Currently I am waiting on my LPP headers and ORY to get back from getting ceramic coated.
This is what I am thinking of running...
Does the set up sound decent. Looking for minimal drone on highway (20 min drive to work highway) but sounds mean when on it at WOT.
LPP - exhaust cutout - bullet or high flow cat - Corsa DB Black - dump behind axle.
I am looking to add a cam and stall next. Do I stick with the 2.5" or go 3"...what do I gain or loose, low end torque? I tow a large smoker to BBQ comp's if that pays a factor in what size pipe you all recommend.
I would like to upgrade to a Magnaflow at some point but right now I am stuck with stock tube and a welded in Corsa unless I can find one for a decent price. I am in a state the does inspections so I need some form of a cat or look like a cat to pass. If the exhaust guy has the right price I would like to replace the entire system...
Any suggestions and part # are great also for the 2007 NNBS 4.8L
Thanks
Old Sep 1, 2011 | 08:17 PM
jvmorgan's Avatar
No one has any suggestions....?!?!?!? I have done a lot of searching and still am confused to a good set-up for the 4.8L
Old Sep 1, 2011 | 08:40 PM
Atomic's Avatar
I have a gauge for that
a single 3" will be perfect for you
Old Sep 1, 2011 | 09:35 PM
jvmorgan's Avatar
Thanks for the recommendation I am going to try and find some part numbers for magnaflow's
Old Sep 1, 2011 | 10:57 PM
Chevy_King1500's Avatar
im running lpp lts and ORY and a 3'' manaflow cat back easy install looks good sounds good 0 drone
Old Sep 2, 2011 | 12:15 AM
jvmorgan's Avatar
What is the part number on your cat back? Did you go with the 14" 18" or 24" muffler set-up on your cat back?
Old Sep 2, 2011 | 12:35 AM
budhayes3's Avatar
PT's Slowest Truck
Sounds like my exhaust would be right up your alley...magnaflows are pretty cheap if you search the net, IIRC, I got mine on Amazon.com...
Here's my exhaust thread (if you skim through the whole thread I added more pics and videos as I went along, I don't have everything in the first post ): https://www.performancetrucks.net/fo...s-vids-479655/
Old Sep 3, 2011 | 11:26 AM
jvmorgan's Avatar
Budhayes3 thanks for the link and recommendation. From what I see I am looking for a very similar set-up.
Old Sep 4, 2011 | 01:26 AM
budhayes3's Avatar
PT's Slowest Truck
Your welcome Yeah, it sounds like you're looking for something along the lines of what I've got
Old Sep 5, 2011 | 08:39 PM
chevyridinhigh22's Avatar
what is the part number for your magnaflow?
