need advice on cam and heads
Old Mar 19, 2007 | 08:17 AM
black03stepside's Avatar
Default need advice on cam and heads
i have a 2003 GMC truck with a 5.3. the truck has over 70K miles on it and is a DD. Iam wanting to put a good cam in it and a good set of heads just wanting to know what would be the best package for my truck and still be able to drive it everyday around town. also know i will need a stall as well what stall should i get????
Old Mar 19, 2007 | 09:15 AM
DamnYankee's Avatar
formerly Moze (2/24/2012)
If you don't have headers I have a Futral cam with a larger split duration fror sale that would work well with the stock exhaust manifolds. Depending on your mods a 2,600 - 3,000 stall would work well.
Old Mar 19, 2007 | 12:20 PM
98TAauto's Avatar
tell us somemore about your truck.. is it 4x4? ext cab? Do you tow with the truck or is it just a DD that you want more power out of?
a good average small cam would be a 210/218 114 or 112lsa for more lope
a good middle of the road cam would be a 218/220ish on 114
a big cam for a truck is getting in the 222/222+ range
of coarse the bigger you go, the more lope and idle issues. I have a 220/220 114 in mine and with tuning you can barely hear the lope. But it drives great! Also, with any cam you will need a stall. If you slap a big cam in and no stall, then most VW beetles will eat you off the line LOL.
WCCH over on the right has some good stage 1 heads for around 700-800bucks.. good for 20hp and 25tq
hope this helps
Old Mar 19, 2007 | 01:46 PM
Default truck
Its a rcsb truck, its 2wd and has 20inch boyd coddington smoothie 2 wheels its has cat-back gibson exhaust and a K@N cold air intake. Its also has stock 3.73 gears. It does have the towing package but i never hall anything at all. i want a cam that sounds very good but still be able to have it as a dd truck. Also where should i go to get the heads and cam installed at i live in NC any ideas will help not a place around here that will even touch it that i know of.
Old Mar 19, 2007 | 03:39 PM
TarheelZ's Avatar
Originally Posted by black03stepside
...where should i go to get the heads and cam installed at i live in NC any ideas will help not a place around here that will even touch it that i know of.
That's the big question, my brother! Most places that I contacted were estimating 20-22 hours for a heads/cam swap. I finally found a guy locally who did it for about half what everyone else was going to charge, but I had to leave my truck with him for a week or so.
Good luck!
Old Mar 19, 2007 | 04:42 PM
Default where in NC
hey buddy! where in NC did you get it done at? I live in Webster, NC about 50miles west of Asheville, NC. Do you know where that is? i dont want to go to far to get it done because of time/money getting there. What rpm stall do you have in your truck? how much did it cost to your install done?? thanks for your help!
Old Mar 19, 2007 | 06:20 PM
98TAauto's Avatar
I'd say a 3200 stall and a 222/222 or 224/224 cam is what you want
depends on what you want to spend
if you lived in Va me and another guy do that work and charge about half what the city people charge.. links in sig
we are getting ready to drop a 5.3 in a truck and take out a 4.8 this weekend
The_W
Oct 28, 2015 09:00 PM
sauldgold
Jul 23, 2015 02:15 PM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
