Throttle body question
Old Mar 19, 2007 | 09:12 AM
sdimess84's Avatar
Default Throttle body question
I am putting an 03 5.3l motor in my S10. the motor I have has the fly by TB on it. I need a cable driven TB. Will an ls1 TB fit to the motor and harness, or do any of you have a stock cable driven TB layin around you would want to sell?
Old Mar 19, 2007 | 10:39 AM
SS_bnoon_SS's Avatar
I believe the plug is different on the DBW TB's, but the LS1 will physically bolt up to the intake manifold. The ECU will have different programming to control the TB motor...
It shouldn't be to hard to wire in your own TPS sensor as the wires are there, and I know people have posted the wiring diagrams on here several times... You should just need the 5V source and the signal back to the ECU from the TPS. Then, all you would have to do is trim off the wires for the motor control and reprogram the ECU to the earlier '99-'02 cable truck setup... I think they use the same ECU, right???
Old Mar 19, 2007 | 11:04 AM
sdimess84's Avatar
Thats what i heard about the ecu. I am having a current performance make me a custom harness, so i guess i will just need to tell him that it is a ls1 TB and he will add the wires and tune the computer.
Old Mar 19, 2007 | 10:20 PM
Quik's Avatar
5 year bitches!
most computers have the settings in htem for the DBW. so you just need to wire up the IAC and the TPS and your set along with tune
jdb11386
Dec 3, 2015 09:34 PM
TimDave217
Aug 24, 2015 04:38 PM
Slammed96
Jul 27, 2015 07:22 AM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
