name that sound
Old Jan 9, 2003 | 01:12 AM
renegade4e's Avatar
14 Second Truck Club
Default name that sound
at higher rpm's, a sound comes from the engine, sort of a crackling noise. it started around the time i descreened the MAS. so today when i plugged in the new hypertech, made the 1-2 shift at 6200 i get a much longer and louder crackling...faster the engine turns, the more the noise is present. anyone know what this is, because it sure doesn't sound good. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 9, 2003 | 02:03 AM
Default Re: name that sound
maybe its pinging?????
try better gas and see what happens
Old Jan 9, 2003 | 05:33 AM
Procharged LM7's Avatar
I would suggest the same, and if it keeps doing it, even with good gas, take the tuning out. detonation will melt your **** fast! The HPP has enough features to where it's worth it to me even w/o the tuning. I will still use the speedo, shift and ! speed limiter when I take my tuning out(I use superchips tuning at present anyway, it's a little better)
Old Jan 9, 2003 | 01:40 PM
XLR8NSS's Avatar
Adkoonerstrator
Does it kinda of sound like popcorn popping or like the ball in a paint can rattling around. If so it's detonation and that's bad. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
The descreened MAF and HPP3 tuning both contribute to this by raising timing and leaning the A/F ratio out. Since you can't very easily change the descreened MAF I would at least take the HPP3 tuning out.
Try better gas also if your not running premium.
If you can hear it pinging like that that's bad.
John
Old Jan 9, 2003 | 01:41 PM
renegade4e's Avatar
1. so what causes detonation?
2. how/what does it melt?
3. would it be because of the descreened MAS?
sorry for the questions, i'm a little lost in what i may be up against.
popcorn...never thought about it like that. but yup, that's it.
Old Jan 9, 2003 | 05:40 PM
CHAGO's Avatar
i think your problem is caused from lack of driving skill! <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jan 9, 2003 | 10:07 PM
detonation is caused by preignition, basically the fuel ignites before the spark plug fires, basically like a diesel, it is from too much cylinder pressure. this force is pushing the crank in the wrong direction basically so the motor will be turning and then all of the sudden there will be a strong force trying to turn the motor the other way. this high pressure can melt a piston because of the extreme temps that form from this, as well as other parts
lukn4trbl355
Oct 21, 2015 11:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Infernohoe
48
Oct 2, 2015 10:25 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Rockrz
Sep 29, 2015 09:07 AM
