mystery cam?
Old Sep 14, 2007 | 09:07 PM
sdimer350's Avatar
Default mystery cam?
i got a zo6 cam off the classifieds and it was supposed to be an 02 cam. I did some rough measuring and it doesnt come out to the .551 lift like its supposed to be. The # on the end of the cam is 4519 s21 5004. i cant make out the # that is stamped on it in between the lobes. anyone recognize this #? i dont want to use it till i know exactly what it is.
Old Sep 17, 2007 | 06:48 AM
sdimer350's Avatar
Nobody? Might have to take it to the dealership and let them examine it.
Old Sep 17, 2007 | 07:08 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
You might want to PM Chevyracer83 -- he's the man for finding part numbers etc. He might be able to help out.
Here's his profile: https://www.performancetrucks.net/fo...er.php?u=69530
Old Sep 17, 2007 | 07:57 AM
Yogi Bear's Avatar
Are you measuring the lift on the lobe or at the valve?
Old Sep 19, 2007 | 02:53 PM
SS_bnoon_SS's Avatar
Sounds like he's doing it at the lobe because he said it's not installed yet. If that's the case, he would need to multiply lobe lift by 1.7 to get stated valve lift measurements...
Lobe lift would be about .324 to equal .551 at the valve...
Old Sep 19, 2007 | 04:49 PM
Yogi Bear's Avatar
That's what I was thinking.
Old Sep 19, 2007 | 05:16 PM
xlcooplx's Avatar
For $25, Thunder Racing will spec it for you!
Old Sep 19, 2007 | 05:21 PM
Tootall's Avatar
here's an `02 Z06 cam
Old Sep 21, 2007 | 02:38 PM
sdimer350's Avatar
yeah i measured the base circle then measured the lobe itself. Then did the subtraction and multiplied that times 1.7 maybe i fucked something up. im gunna go measure it again. and i took it to the dealership, and he said gm doesnt put part #s on cams, havent since the gen1 smally.
Old Sep 21, 2007 | 08:24 PM
ricoc's Avatar
hard to believe try another dealer partsman
