my truck wont start need help please!!!
Sounds like there is high resistance in the fuel pump circuit from the tank connector in. I've seen guys breaker that circuit looking for the short, finally removed the tank to find the fuel pump wires melted.
The circuit is quite simple. Your truck wants a fuel pump. I have seen this a few times, very possible. just not super common. Check fuel filter if you see black fuel come out inlet that is another sign of fuel pump brush wear. Oh you asked where high resistance is? It is in the fuel pump itself, brushes armature-not sure never been that courious.
Chances are you had the same thing that I experienced a month ago, but mine did not pop a fuse. The connector, if it is the old square type, is prone to failure. I hav epictures of the old and new style connector. See the post I made about replacing your fule pump:
https://www.performancetrucks.net/fo...mp+replacement
Its fixed it turned out to be the fuel pump after all. It did like powerpimp said and had a lot of black fuel come out when i disconnected the fuel lines. So if you have a problem with the ECM fuse poping you should check your fuel pump. Thanks for all the help guys!
cams 98 silverado
Jul 31, 2015 07:36 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
